Losing alot of coolant out of cats! - Page 2 - JeepForum.com
 9Likes
post #16 of 27 Old 06-14-2021, 12:42 AM
Delta0
Originally Posted by Golden-Arm View Post
pressurize the cooling system, and find the leak. you might have to pull the exhaust manifold(s), valve cover(s) to find it. just because you "know it's leaking" doesn't mean you don't test it. if it doesn't leak without pressure, how will you ever find it? i'd be checking my oil for water in it, and as mentioned above, water leaking into the manifold could run the other direction, and hydro-lock a cylinder. pressure testing is free. replacing a bent rod, maybe not as free......
Spot on Matey.
Delta0 is offline
post #17 of 27 Old 06-15-2021, 10:02 PM
Bigrigr
Bigrigr's Avatar
Didnt we have someone on here a little while back that bought heads that came without some plugs installed? Was It Cdee63?
underscore likes this.
'00LMTD-4.7l,242hd,D30,D44A,3.73's,True-trac front,Spartan rear,4" short arm lift,JK'sW/32's
Bigrigr is offline
post #18 of 27 Old 06-16-2021, 07:23 AM
sdg3205
sdg3205's Avatar
Did you clean out the head bolt cavities well and use a chaser? if you get oil, coolant or debris down there you risk not getting proper torque.
sdg3205 is offline
post #19 of 27 Old 06-16-2021, 09:00 AM Thread Starter
Blacksailsdive
Finally got a chance to check out your guys suggestions. Spent the morning taking everything back apart, did perform a pressure test on the coolant system which did not show the same leak in the header "holes". Instead a slight leak on the timing cover which should be an easy fix. Drained some oil, damn there is a lot of coolant in there, attached a picture of that as well. Also a picture of the valve gap on one of the headers but im fairly sure thats just pushed down by the cam. So main culprit is coolant leaking into the oil pan/engine and out of the exhaust manifold. Since I have the heads back out is there a best way to see what the hell is going on? Also a picture below of the hole where the coolant has been pouring out of before the cats.
20210616_104301_1623855402946.jpg   20210616_104307_1623855414129.jpg   20210616_104312_1623855423863.jpg   20210616_104504_1623855435027.jpg   20210616_104511_1623855446364.jpg
20210616_104516_1623855468905.jpg   20210616_104602_1623855483740.jpg   20210616_104609_1623855496613.jpg   20210616_105001_1623855505977.jpg   20210616_110324_1623855851566.jpg
Blacksailsdive is offline
post #20 of 27 Old 06-16-2021, 09:41 AM
sdg3205
sdg3205's Avatar
Did you clean/prep the deck of the block before?
sdg3205 is offline
post #21 of 27 Old 06-16-2021, 10:12 AM Thread Starter
Blacksailsdive
Yes, probably hard to tell in the picture but I cleaned all the gasket mating surfaces and razor blade scraped all of them clean followed up by some heavy degreaser.
post #22 of 27 Old 06-16-2021, 07:26 PM
Golden-Arm
Golden-Arm's Avatar
i haven't dealt with a 4.7 motor before, but i am noticing you have direct contact roller rockers, without pushrods. this can allow for almost zero lash, and is probably the most responsive setup, for valvegear. you should be able to adjust the lash out of that setup, with no issues. if you see no wear pattern on the cam lobes, and the rocker wheels are all round, roll freely and don't have scorching or flat spots, you are good to go.
those two super clean, shiny pistons tell me, they are being "steam cleaned", and are getting water into the bores. you'll need to chase down the source, either leaking head gaskets, crack/hole in cylinder walls, maybe a warped head, or a nick/bump on the block near those two holes. get a straight edge, and check the block and heads. in multiple directions, looking for a gap, or by feeling a bump. (slide the flat edge around, side to side, up and down, and look for a gap or if it stops itself, find out why)
the water in the oil is troubling. the cylinder walls, or water leaking through the head into the valve area is really the only way to get water into the oil. (unless the shop pulled the heads, and let the water from the heads (if any were present) to drain into the center galley, and fall into the sump)
a leak in the timing cover, from the waterpump, could be possible, but rare. the back side of the pump housing would have to be leaking, into the front oil gallery. good luck getting it sorted, and hopefully you don't wipe the bearings, trying to find the source of the leak.
WJ60 likes this.
Uphill Slow, Downhill Fast, Tonnage First, Safety Last!
Golden-Arm is offline
post #23 of 27 Old 06-16-2021, 08:57 PM
WJ60
WJ60's Avatar
Just what I was thinking ^^^^^
WJ60 is offline
post #24 of 27 Old 06-17-2021, 09:28 AM Thread Starter
Blacksailsdive
The heads pictured are new to me and were just remachined although I think them to be the defect now. I know what you mean about the piston heads but trust me they were all the same color before I cleaned everything up. The original heads had been overheated and were misfiring on #8 which was about to drop the valve seat so I went ahead and bought new heads for both sides. After the fourth install of the new head which was done with multiple sets of new head gaskets and head bolts, im convinced that the remachined heads I got have some sort of defect. Im talking coolant running out of the headers like a hose. Im going to contact the shop today and start the warranty process, while I cant see any obvious defects via boroscope or naked eye, the coolant leaks are only happening when starting the engine or when it is running. I cant recreate the same leak by pressurizeing the coolant sysyem with a hand pump!
post #25 of 27 Old 06-18-2021, 04:58 PM
skatulaki
I have " Heard " but never seen and cannot confirm. That if you put the serpentine belt on wrong it will blow the coolant out of them. Sometimes it's that simple. Just thought I would throw that in there.
skatulaki is offline
post #26 of 27 Old 06-18-2021, 06:27 PM
anotherheep
I take it you had the coolant system full when you pressure tested? What tool are you using to pressurize the system? Do you have pictures of the ENDS of the heads?
anotherheep is offline
post #27 of 27 Old 06-18-2021, 06:35 PM
anotherheep
Sounds like you need some good spot lights and a big hand held mirror to look behind at the situation. I know saying and actually being there are different things though
