Light in the dashboard. - JeepForum.com
 1Likes
  • 1 Post By Bigrigr
post #1 of 7 Old 05-28-2020, 08:30 AM Thread Starter
Fed911
Fed911's Avatar
After replacing the lamps, the backlight does not turn off even when the ignition is off. There is no reaction to a change in brightness either. The lights of the walkie-talkie and air conditioner behave normally. Tell me where to look?
Sorry for my google english : Frown2:
Fed911 is offline
post #2 of 7 Old 05-28-2020, 02:11 PM
SD Overland
SD Overland's Avatar
What kind of bulbs did you replace them with?
04 Overland 4.7 HO, IRO 3'', Billstein 5100
BFG 245 70R17, 1.5'' wheels pacers, Addco rear sway bar
SD Overland is offline
post #3 of 7 Old 06-03-2020, 02:32 AM Thread Starter
Fed911
Fed911's Avatar
I installed the same lamps as on the dashboard. Chinese noname that I managed to buy in my village)
Fed911 is offline
post #4 of 7 Old 06-03-2020, 09:04 AM
2oldjeeps
chech the "magic" do-everything turn signal switch positions.
i cant figure it but it does things like that...
99wj,143,000 miles
00xj,177,000 miles
10hummer3,74,000 miles
98xj,130,000 miles
2oldjeeps is offline
post #5 of 7 Old 06-03-2020, 01:11 PM
Bigrigr
Bigrigr's Avatar
Basic rule of thumb #1. If you are gonna work on a Jeep, you must always remember. What ever you touched last is the first place to start when chasing a problem that popped up after doing a change. I would be pulling that gauge cluster back out and looking for bent over pins on the connectors on the back. Gotta be something going on back there....
2oldjeeps likes this.
'00LMTD-4.7l,242hd,D30,D44A,3.73's,True-trac front,Spartan rear,4" short arm lift,JK'sW/32's
Bigrigr is offline
post #6 of 7 Old 06-05-2020, 03:16 PM Thread Starter
Fed911
Fed911's Avatar
I took out all the lamps, left only the backlight. There is no result, it is still burning.
I showed the dashboard to a local electrician, he said that there was no damage, maybe there was a problem with the control chip in the dashboard itself?
Fed911 is offline
post #7 of 7 Old 06-06-2020, 11:12 AM
Bigrigr
Bigrigr's Avatar
Well, you know it isnt the bulbs then, possible something went haywire in the chip....
Bigrigr is offline
