Lift and Weight Issues - JeepForum.com
post #1 of 7 Old 08-22-2018, 11:40 PM Thread Starter
TC2411
2003 WJ
Question Lift and Weight Issues
Hello Everyone. I have an 03 overland with a 4" long arm lift right now. It worked flawlessly with little accessories added to it. It now squats pretty good with the extras i have put on. The lift is only a year old so i'm sure its not sagging. I put on front and rear flatland bumpers, winch and mounted the spare tire outside (no room - Tank tuck completed). I also mounted 2 jerrycans for fuel. I built a kitchen complete with an ARB fridge as well as a box for all recovery gear and dry goods. Both of these are made out of aluminium. I took off the factory roof rack and made one out of 2" aluminum pipe which also can be filled with water (5.5 gallons) for showering, providing water to wash the dishes or to clean the mud out of the rad etc. I just bought a roof top tent and mounted it as well. I have no problem getting down the highway or going offroad in the mountains, it's just that i have very limited travel now for any articulation. Question is do i go with Clayton 4.5" springs which give me a higher spring rate (225lb instead of 188lb- RC) or should i go the 6" of the same spring rate. Of course i will change to the matching Bilstein shocks. Also, If i go with a higher lift, does it affect the hill climbing ability of my rig? Definately need words of wisdom
TC2411 is offline
post #2 of 7 Old 08-23-2018, 06:38 AM
Motorcharge
Motorcharge's Avatar
It's really kind of a wash depending on how the weight effects it. It's going to ride worse with stiffer springs to get to the same height, but given the weight a taller spring may just compress to where you want it to sit. The current springs are likely compressed more than they should be due to the added weight. Easiest way to confirm this would be to pull off heavy items and see if it comes back up.
And yes, the higher you sit the higher your center of gravity which is a big factor in climbing.
|SOLD|
| June 2015 COTM |
Motorcharge is offline
post #3 of 7 Old 08-23-2018, 09:25 AM
Jeeples
Harsh, but fair
Jeeples's Avatar
Spring rate is a rating that's assigned based on how many lbs. it takes to compress the spring one inch.
Your RC springs are rated at 188 lbs, but there's 2 per axle, so it would take 376 lbs to compress them 1". Clayton would put you at 450 lbs.
This thread has some great info about the available spring rates for WJ's:
https://www.jeepforum.com/forum/f310...rates-4317125/
You've add a lot of weight to your WJ, between the bumpers, the roof top tent (those several hundred pounds on their own depending on what size you've got) and your mini-kitchen. You're also carrying a decent amount of liquid between the spare the fuel and water you can carry in the roof rack, not to mention any other cargo you toss in (coolers, water bottles, clothing, etc.)
I would personally go with the highest rate springs I could get if I were in a similar situation. In this case that would be the BDS/Zone 4" springs rated at 240 lbs front and rear. However you're still going to experience sag due to the weight, at that point you may need to look at some 1" spacers to help retain your wheel well clearance.
Stepping up to 6" springs through Clayton or IRO will yield you the same rear weight capacity, but the fronts are a bit lighter, so front spacers may be necessary still. On top of that you'll likely need new shocks as well.
I don't know what your preferred terrain type is, but I have a buddy that wheeled with a Tepui rooftop tent at 6" of lift and he said the weight transfer on off camber situations after the tent was added was pretty unsettling. He ended up selling it shortly after.
His: '00 WJ 4.7 Limited- Some stuff
Hers: '03 WJ 4.7 Laredo- Some more stuff
Originally Posted by Jeeples
This is easily the worst post, and thread, I have ever seen in 7 years of being on JF.
Jeeples is offline
post #4 of 7 Old 08-23-2018, 10:22 AM Thread Starter
TC2411
2003 WJ
That's a great explanation Jeeples. I did talk to the Reps at Rough Country and they confirmed the spring rates at 180lbs for front and 188lb for the rear on the 4" lift springs. Maybe we could add that info to the chart.
I do moderate to difficult trails. I'm thinking that I will not go the 6" route considering your comment about the off camber situation.
FYI, the weight of the RTT is 135lbs. I have noticed a slight difference when off-roading but I'm always mind full of the fact it's up there.
Right now, I find the springs too soft and the shocks don't really control the springs. I'll go to a heavier spring and a better quality shock. Any suggestions on the shocks? Bilsteins?
Also, where can I find the 1" rear spacers that you talked about?
TC2411 is offline
post #5 of 7 Old 08-23-2018, 10:35 AM
ravenworks
ravenworks's Avatar
You may consider Airlift bags
Semper-Fi "81-84"
I.U.O.E. - 18
ravenworks is offline
post #6 of 7 Old 08-23-2018, 12:55 PM Thread Starter
TC2411
2003 WJ
Ravenworks…. How do the airlift bags hold up to the offroading aspect. Would be good for carrying the weight of a load
TC2411 is offline
post #7 of 7 Old 08-23-2018, 02:10 PM
Jeeples
Harsh, but fair
Jeeples's Avatar
I find the Bilsteins to be a little soft, at least when paired to the standard IRO springs. Fox has a full line offering for the WJ now for lifts up to 8", from what I've heard the 2.0 IFP series are a little stiffer compared to the Bilstein 5100's. Paired with a heavier rated springs they should provide the control you're looking for with a Jeep that typically runs heavy.
I've seen 1" (and other size) spacers on eBay and Amazon, but don't have any experience with any of the vendors so I can't really recommend one over the other.
Jeeples is offline
