Lift question - JeepForum.com
 3Likes
post #1 of 23 Old 06-21-2021, 08:56 AM Thread Starter
Docfitch
Lift question
I need clarification. I just got an 04 wj with 4.7 ho and quadra drive. I want to put a small lift on it - 2.5 inches or so. I have read that you canít lift an awd vehicle. Is this true. If so, there appear to be quite a few people doing it. I figured if I stayed under 4 inches, i wouldnít have make a lot of changes.
Docfitch is offline
post #2 of 23 Old 06-21-2021, 09:12 AM
smokeyyank
smokeyyank's Avatar
They say that because of the repezza drive shaft. You have an 04 so shouldn't be an issue putting a little lift. Under 3" not a lot of changes going to 3-4" you'll have a good amount to get it right.
Bigrigr likes this.
04 WJ, 4.7HO
3" IRO lift, fastman TB, 32s, lunchbox rear 242HD, 3" exhaust
smokeyyank is offline
post #3 of 23 Old 06-21-2021, 09:12 AM
GmanWJ
GmanWJ's Avatar
You can lift it. Check your front drive shaft; if it has a double cardan joint on the TC side and u-joint on the axle side, you should not have much of a problem. On the other hand, if you have a DS with a Rzeppa joint, lifting is not recommended because the joint will probably fail. Either replace DS or do not lift.
2.5" OME HD & Bilsteins
Dual Batteries
Aux Trailer Hookups (4awg charging & backup cam)
GmanWJ is online now
post #4 of 23 Old 06-21-2021, 09:19 AM
underscore
Or rebuild the Rzeppa joints if they fail. I swapped to a DC, but the more I dug into it after the fact the more I saw cases of people not needing to do it. If I was doing it all again I'd just rebuild my stock ds.
00 WJ
[x] 07 WK CRD/OME/MALONE 1.5 [x] 00 XJ/OME [x] 97 TJ [x] 92 YJ
underscore is offline
post #5 of 23 Old 06-21-2021, 09:33 AM Thread Starter
Docfitch
Got it. So itís the drive shaft angle that is the concern.
Docfitch is offline
post #6 of 23 Old 06-21-2021, 10:00 AM
leadsled jeep
leadsled jeep's Avatar
IF one has that rezzepa DS only, yes. Of course this is a Jeep so aftermarket upgrade support is awesome. Lots of us run 2.5”+ suspension lifts. Perhaps more here a Have a lift than do not!
'02 4.7HO 235k ml. 2.5" BDS. Aftermarket arms & Addco sways. 245-70-17. Stock engine/tranny. Amsoil
leadsled jeep is offline
post #7 of 23 Old 06-21-2021, 05:33 PM
CJREX
CJREX's Avatar
Being an 04 with the 4.7 and Quadradrive, I'm thinking he has the double cardan front driveshaft and won't need to change it.
2004 GC Overland 4.7 HO
Powerful Wanderer (wife named it after driving it)
265/70/17 MT, 2" BDS lift
CJREX is offline
post #8 of 23 Old 06-21-2021, 05:57 PM Thread Starter
Docfitch
It looks like u joint on the transfer case end.
Docfitch is offline
post #9 of 23 Old 06-22-2021, 04:34 AM
CJREX
CJREX's Avatar
A double cardan is a double U-joint. If you have one like the picture below on the T-case and a regular U-joint on the axle end you are good to go.
CJREX is offline
post #10 of 23 Old 06-22-2021, 08:26 AM Thread Starter
Docfitch
Nope. It looks like a regular u joint on tc.
Docfitch is offline
post #11 of 23 Old 06-22-2021, 09:32 AM
GmanWJ
GmanWJ's Avatar
On the front or rear DS? With a 4.7 HO, I would have thought you have a double cardan on your front DS, but I have been wrong before.
Dual Batteries
post #12 of 23 Old 06-22-2021, 11:59 AM Thread Starter
Docfitch
The front. I was hoping it was a double cardan, but it doesnít look like it.
Docfitch is offline
post #13 of 23 Old 06-22-2021, 12:47 PM
underscore
So it has one ujoint at each end?
00 WJ
post #14 of 23 Old 06-22-2021, 01:40 PM Thread Starter
Docfitch
Yep. But, if I stay under a 3 inch, I should be o.k.
Docfitch is offline
post #15 of 23 Old 06-22-2021, 02:04 PM
smokeyyank
smokeyyank's Avatar
You have a 04 you'll be fine. It was the earlier years that have the problem driveshaft.
04 WJ, 4.7HO
