Keyless Remote Entry - JeepForum.com
 6Likes
post #1 of 23 Old 07-05-2019, 08:44 AM Thread Starter
TastyWheatLoaf
TastyWheatLoaf's Avatar
Hello, I purchased a WJ used recently and it didn't come with the remote when I bought it. I haven't had a chance to stop at a dealer to have them check/ quote out getting ones programmed. But I was wondering if they came without that as an option and if there is a way for me to check before doing that.Thanks!
TastyWheatLoaf is offline
post #2 of 23 Old 07-05-2019, 10:24 AM
DJCantonGA
DJCantonGA's Avatar
I'm sure someone will chime in soon to confirm, but I think most WJ's came with keyless entry.
Tip: you don't have to pay an arm and leg at the dealership for new remotes and programming. I ordered a few replacements from Amazon, and a member here will send you a programmer for around $15. I did that a few months ago, and it worked like a charm.
Bigrigr likes this.
DJCantonGA is offline
post #3 of 23 Old 07-06-2019, 06:18 AM
AVR2
Yep, keyless entry was standard equipment on all WJs.
AVR2 is offline
post #4 of 23 Old 07-06-2019, 09:41 AM
Flexn247
Flexn247's Avatar
Hey where can I get more info?
Flexn247 is offline
post #5 of 23 Old 07-06-2019, 09:55 AM
ShinyWJ
You can get a programmer with keyless remote on Amazon for $66 right now - https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
The price may fluctuate, I bought this late last year for $56.
If anyone just needs to use the programmer, PM me and I'll send it to you for $15 so you can use it and send it back.
2002 WJ Limited | 4.7 | Quadra-Drive | Inferno Red Pearl | Dark Slate Gray
ShinyWJ is offline
post #6 of 23 Old 07-06-2019, 11:00 AM
DJCantonGA
DJCantonGA's Avatar
Hit up @EisBlade .
post #7 of 23 Old 07-07-2019, 01:05 AM
EisBlade
EisBlade's Avatar
Hit up @EisBlade .
Thanks, DJ!
DJCantonGA likes this.
[SOLD] 3" OME + IRO Rock-Link LA; balanced Titan motor w/ stroker cam, ported heads; 3.73 VariLok + NP242; Raptor coated.
FOR RENT: Key Fob Reset Tool $15 [free shipping] Tool resets multiple key fobs for 1999-2004 WJ's, 2000-2005 Neon, 2001-2005 PT Cruiser. PM to coordinate.
EisBlade is offline
post #8 of 23 Old 07-07-2019, 06:00 PM Thread Starter
TastyWheatLoaf
Thanks guys! I will look into this option. Also has anyone tried out those dorman fob and programmers, I know they usually run like 80ish bucks.
post #9 of 23 Old 07-07-2019, 07:26 PM
DJCantonGA
DJCantonGA's Avatar
That is exactly what you can rent from Eisblade. Works great.
EisBlade likes this.
post #10 of 23 Old 10-22-2019, 03:06 PM
EisBlade
EisBlade's Avatar
I expect the programmer back by the weekend in case anyone wants it shipped next week. PM to coordinate.
EisBlade is offline
post #11 of 23 Old 10-23-2019, 07:58 AM
Mattyjm
Mattyjm's Avatar
I did try the Dorman fob and programmer. The Dorman fob worked great for a couple months, then stopped unlocking the doors. I wound up taking the passenger door module and fob from my 2000 WJ and installed the PDM into my 2002 WJ. It's still working great today.
2004 Special Edition WJ. LOADED!
2004 Rocky Mountain Edition. Froggy Bandit. Wife's Daily Driver. PRISTINE! Stock height and may stay that way.....
Mattyjm is offline
post #12 of 23 Old 10-24-2019, 10:00 AM
GmanWJ
GmanWJ's Avatar
I think I'm going to hop in line for this programmer @EisBlade . I found a fob laying around from my old 1999 WJ that I would like to reprogram to work with my 2002. Sounds like your programmer would do the job.
ok mostly just repairs, but we are closing in on a lift
GmanWJ is offline
post #13 of 23 Old 10-28-2019, 05:13 PM
EisBlade
EisBlade's Avatar
I just received it back so it's ready to ship immediately. Just send a PM when ready. Might need new batteries if unsure when they were last replaced. Batteries required: two cr2016
I found these for $3 on Amazon w/ free shipping.
3V Lithium Button Cell Battery Retail Pack - 2-Pack
EisBlade is offline
post #14 of 23 Old 10-29-2019, 03:07 AM
99wjtx
99wjtx's Avatar
FYI - If two 2016 batteries are stacked when installed, a single 2032 will work instead. Apparently, two 2016s have a total capacity of about 180mAh whereas one 2032 has about 240mAh.
Rage! Rage against the dying of the Jeep.
99 WJ Limited 4.7/NV247
01 WJ Laredo 4.7/NP242
99wjtx is offline
post #15 of 23 Old 10-29-2019, 02:16 PM
CutterBill
1992 XJ Cherokee
Bought one over a year ago. Still working well. The only issue I had was that I had to climb in and shut the door before the programmer would work. But that did the trick.
Bill
CutterBill is offline
