key will not turn need help asap - JeepForum.com
post #1 of 8 Old 03-12-2012, 02:26 PM Thread Starter
Amadauss
Amadauss's Avatar
Put the key in ignition and pulled car into garage half way in. Wanted to work on brakes so turned steering wheel all the way to right to expose caliper better and realized had to pull car in further. Put key in and it will now not engage. Flips to the on position the other way but will not turn to start. Did read about tapping the key lightly and that sometimes will help it engage but wheels are locked and key will just not turn. Need to move car. Any thoughts?
Amadauss is offline
post #2 of 8 Old 03-12-2012, 02:28 PM
Chris00WJ
The steering wheel is locked. Turn it hard all the way to either side while turning the key. The key word is hard. It should unlock. There's too much pressure on the column.
2000 Jeep WJ Laredo - 4.7L, 3" IRO Lift kit, JKS adjustable track bar, 242J TC swap, BFG KM2 32's on JK takeoffs, Leather interior swap, Custom CAI, front hitch receiver, homelink EVIC swap etc
Chris00WJ is offline
post #3 of 8 Old 03-12-2012, 03:58 PM
OTownDaddy
OTownDaddy's Avatar
2007 XK Commander
^^^^^ that's probably the issue, but you can also try taking it out of park and back into park, might not have gotten all the way in.
2007 XK Limited 4x4 | QD-II | 18" wheels (gotta dump these for some 17s) | The rest is stock
OTownDaddy is offline
post #4 of 8 Old 03-12-2012, 04:35 PM
Bluefish94
Bluefish94's Avatar
Pull on it very hard, to the point you think its going to break, then all the sudden the key will turn. Had the same issue with mine.
Bluefish94 is offline
post #5 of 8 Old 03-12-2012, 04:38 PM Thread Starter
Amadauss
Amadauss's Avatar
all were so right. The key word was hard. I had to put a lot of pressure on it but it worked. Thanks very much!!!!!!
Amadauss is offline
post #6 of 8 Old 03-03-2013, 10:38 PM
KellyannD
Same issue.....locked up on me tonight. We have pushed, pulled, poked, prodded, yanked, shaken (but not stirred).........all to no avail. I tried, then put 3 men on it. She's not budging. Any other Words from the Wise would be really Amazing right now. She's stranded in a parking lot and I'd like to get her home.
Thanks!!
Kellyann
KellyannD is offline
post #7 of 8 Old 03-04-2013, 07:11 AM
dillonjm
dillonjm's Avatar
2013 WK
Thanks!!
Kellyann
Check the shifter is fully seated in park. Mine is a little touchy and sometimes doesnt click all the way in and won't let me turn the key to get it out or turn all the way to start. A little bump forward on the shifter until I hear a click and then everything works fine.
JEEPLESS
Past Jeeps: 13 GC, 99TJ, 78CJ7, 91YJ, 01WJ, 03TJ, 05KJ
dillonjm is offline
post #8 of 8 Old 03-04-2013, 10:02 AM
Highschool_WJ
Highschool_WJ's Avatar
Had a similar problem but the wheels were straight and I finally got mad and punched the key in further and tried turning it on and it started right up
,,,soooo I graduated in 2013...
Highschool_WJ is offline
Need help asap rkperry1 WJ Grand Cherokee Forum 5 10-16-2011 01:58 PM
**** .....I need help, asap. 00WJGC WJ Grand Cherokee Forum 20 01-17-2011 07:36 AM
HELP! HELP! asap X2 SwaYY WJ Grand Cherokee Forum 2 05-29-2010 04:05 PM
Help help asap!!!!! SwaYY WJ Grand Cherokee Forum 1 05-29-2010 08:20 AM
