JK/WJ swapped axel steering question - JeepForum.com
post #1 of 1 Old 06-18-2021, 11:46 PM Thread Starter
spottedfrog
spottedfrog's Avatar
1979 CJ5
For those of you that have done the JK front axle swap, Did you use the JK or the WJ drag link? Going to assume you used the JK tierod because the JK spring perches and sway bar mounts wont allow the WJ one? also not sure you'd have the length in the WJ bar.
I'm mostly concerned about length. I'm swaping on WJ style mounts so I could use WJ style tierod if there is enough adjustment.
have Reid racing high clearance knuckles though.
I want to get the Trail Forged set up, but not sure if I'd have to try and get longer versions.
Thanks.
spottedfrog is offline
