Jeep WJ Rear brake line lenght - JeepForum.com
post #1 of 11 Old 06-27-2020, 03:23 PM Thread Starter
slavo
Wj Jeep WJ Rear brake line lenght
Need to replace the rear steel brake lines (those once running along the rear axle - left and right)
What lengths should I buy?
slavo is offline
post #2 of 11 Old 06-29-2020, 10:50 AM
Hudsonhawk59
I just bought some copper nickel brake pipe and fittings and made them to fit. The pipe was easy to bend by hand without damaging it.
Hudsonhawk59 is offline
post #3 of 11 Old 06-29-2020, 05:02 PM
Golden-Arm
Golden-Arm's Avatar
you should be able to purchase the lines pre-bent, with fittings already installed, based on the year and model of your ride. measure the ones coming off, and use that number to double-check the ones you buy. pretty simple really.
Uphill Slow, Downhill Fast, Tonnage First, Safety Last!
Golden-Arm is offline
post #4 of 11 Old 06-30-2020, 08:38 AM Thread Starter
slavo
Pretty simple if I had those. I cut them, threw them away and then figured out I didn't check the lengths. Update: I ordered dorman lines. I was trying to install not pre-bent ones and striped threads in the axle hose. Total bummer. The problem is you need to know what flaring to use. Those once I bought were single flared and didn't work. Sometimes it's just better not to be cheap.... I'm two weeks behind the schedule now since I need to wait two weeks to get the dorman once.. bummer again
slavo is offline
post #5 of 11 Old 06-30-2020, 08:55 AM
2oldjeeps
i take old parts to az to be sure the new match. you can buy longer lines and bend a loop to fit,ez.
ugly but noone sees them...
99wj,143,000 miles
00xj,177,000 miles
10hummer3,74,000 miles
98xj,130,000 miles
2oldjeeps is online now
post #6 of 11 Old 07-01-2020, 08:39 AM
Golden-Arm
Golden-Arm's Avatar
i'm posting this to show how easy this is, not to suggest or endorse the company listed. all pre-bent rear lines for your jgc are the same. just order a pre-bent set. there's nothing to guess about lengths, diameters or fittings. you are over-complicating this, by trying to bend stuff yourself, without knowledge of lengths, where the supporting coil springs go (if applicable) or fitting types. https://classictube.com/product/jeep...1200220032004/
post #7 of 11 Old 07-01-2020, 07:00 PM
AVR2
That set is good value - $199 for all the hard lines front and rear. If you look up Mopar prices, just the longer rear axle line alone is well over $100 these days, and I think the front-to-rear line is around $180.
AVR2 is offline
post #8 of 11 Old 07-02-2020, 10:02 AM Thread Starter
slavo
I did order a dorman OE replacement. I don't like tinkering with brake systems. Paid $177 for it. just dunno when it arrives. I also tried to diy and (guess what) stripped the threads in the metal cube attached to the real axle so no thank you for diy bending.
slavo is offline
post #9 of 11 Old 07-02-2020, 10:27 AM
2oldjeeps
factory or not ,it aint ez to line up threads. you may do it again. you might need to bend it a little !!
99wj,143,000 miles
00xj,177,000 miles
98xj,130,000 miles
post #10 of 11 Old 07-05-2020, 06:25 PM
Uniblurb
Uniblurb's Avatar
As far a 'ClassicTube' prebent brake lines I hope their kits and service are better than 4 years ago. Below is what happened to a member I became friends with over on the ZJ forum where his kit lines were wrong, didn't fit, had to used adapters, etc..
https://www.jeepforum.com/forum/f13/...lines-3756801/
Look at the link within my thread for more details. After a nightmare customer service experience at least ClassicTube finally refunded his money.
2004 4.7L WJ Limited, 96 4.0 ZJ
Uniblurb is offline
post #11 of 11 Old 07-06-2020, 08:15 AM Thread Starter
slavo
I ordered Dorman replacement from a local store.
slavo is offline
