Iron Rock Off-road lift - JeepForum.com
 2Likes
  • 1 Post By coldspit47
  • 1 Post By smokeyyank
post #1 of 10 Old 09-14-2020, 07:13 AM Thread Starter
DrunkLolbert
Anyone ever used their lifts? Specifically the 8” rock-link long arm? I have a lift already on my WJ and I was thinking of getting the IRO 4 link upgrades but I’m also considering just redoing the lift completely with this kit.
DrunkLolbert is offline
post #2 of 10 Old 09-14-2020, 02:28 PM
MuloChico
2006 WK
I haven't used their lifts but I have used several of their parts over the years and have never been let down yet (key word).
MuloChico is offline
post #3 of 10 Old 09-14-2020, 08:34 PM
smokeyyank
smokeyyank's Avatar
I run the 3". I've always like IRO. Wouldnt hesitate to run their LA either.
04 WJ, 4.7HO
3" IRO lift, fastman TB, 32s, lunchbox rear 242HD, 3" exhaust
smokeyyank is offline
post #4 of 10 Old 09-14-2020, 09:25 PM
SoCal2004wj
SoCal2004wj's Avatar
Running the 4" lift on my WJ. The quality and build has been top-notch!
SoCal2004wj is offline
post #5 of 10 Old 09-14-2020, 10:12 PM
GriffLvr
Junior Member
GriffLvr's Avatar
Just curious is that the long arm or short arm 4" lift? Thanks
GriffLvr is offline
post #6 of 10 Old 09-14-2020, 10:13 PM
GriffLvr
Junior Member
GriffLvr's Avatar
Sorry should have doubled up my ?'s. What shocks did you go with and what are your thoughts about your choice. Thanks
GriffLvr is offline
post #7 of 10 Old 09-15-2020, 06:55 AM
coldspit47
I have their Bilstein 3in set on all adjustable short arms (front upper/lower, rear lower, rear upper a-arm/boomerang) and it's great to be able to correct caster and pinion angle. I've had one trackbar bushing fail me (installer error) in the 5.5 years the lift has been on and both the rubber boomerang inserts failed (installer error). I now have the flex joints on all three corners of the boomerang - they do transmit significantly more harmonic vibrations though, so keep that in mind if it's a DD.
The parts are heavy, make no mistake, but other than mild oxidation they appear and function as well as the day I got them. My ride quality is perfect for me (and shockingly my wife). I highly recommend them - check with @Kolak for best pricing and knowledge. If you aren't going to be slow crawling over boulders and need a bajillion degrees of flex, their 3 link is just fine instead of 4 link. It still has loads of adjustment and travel.
I have their transfer case yoke, SYE (which is really what appears to be a Tom Woods badged Advance Adapters), rear driveshaft (rebadged Adams), front shaft on the way, and lift. They're always the first company I think of when I need aftermarket WJ parts.
Kolak likes this.
JEEP. making mechanics out of ordinary folks since 1940.
coldspit47 is offline
post #8 of 10 Old 09-15-2020, 01:19 PM
smokeyyank
smokeyyank's Avatar
I run bilsteins on mine. Overall ride has been great. My issues is clunking from the control arms that where replaced but those where stock and not IRO's. I'll eventually swap in LA.
SoCal2004wj likes this.
04 WJ, 4.7HO
post #9 of 10 Old 09-15-2020, 11:31 PM
SoCal2004wj
It's actually a 4" lift on short arms. Drives great on the highway and does well off-road as well. No complaints
post #10 of 10 Old 09-17-2020, 10:31 AM
UncleWoody
UncleWoody's Avatar
I run the IRO 4-link long arm kit with Bilstein shocks and 265/70/17 tires. It was performed well for me, I run up to moderate trail here in northern Arizona. The only additional thing that I had to do was to raised the front for about an inch and a half because the weight of the winch and the winch plate had sag the front too much. I got the desired lift by removing the top spring isolator and adding a 2" light booster. Here is the link to my build thread.
https://www.jeepforum.com/forum/f197...03-wj-4255753/
"If we can really understand the problem, the answer will come out of it, because the answer is not separate from the problem"
UncleWoody is offline
