Instrument Cluster Bulbs - JeepForum.com
 2Likes
  • 1 Post By tebeve
  • 1 Post By 99wjtx
post #1 of 7 Old 10-21-2019, 05:40 PM Thread Starter
E55&98 Jeep
Two of my bulbs are burnt out and I tried finding replacements with no luck. My manual calls for 103 bulb and PC74 for the warning lights but I read you can fit the PC74 where the 103 should go. I was able to find 6 PC74 from Napa Auto. I wanted to ask before I pull the cluster to make sure the PC74 will work. Thanks
E55&98 Jeep is offline
post #2 of 7 Old 10-22-2019, 05:06 AM
99wjtx
99wjtx's Avatar
I looked into this a number of years ago and if I remember correctly the answer is yes the smaller bulb will plug in and work. It just may not appear quite as bright.
The 103 bulb is rare and expensive so using the 74 is a common hack. You might like the result better if you switch them all out for consistency, or doing a full LED conversion while you're in there.
Rage! Rage against the dying of the Jeep.
99 WJ Limited 4.7/NP242
01 WJ Laredo 4.7/NP242
99wjtx is offline
post #3 of 7 Old 10-22-2019, 07:50 AM
tebeve
tebeve's Avatar
2003 WJ
When I replaced mine, I made the switch to LED, so I don't have much to offer on your original question of size swapping... but if you'd like to go down the rabbit hole of LED cluster light replacement, here's the thread with everything you need to know!
IturrGuate1975 likes this.
tebeve is offline
post #4 of 7 Old 10-22-2019, 09:16 AM
99wjtx
99wjtx's Avatar
Here's a 74 and 103 comparison.
99wjtx is offline
post #5 of 7 Old 10-22-2019, 03:03 PM Thread Starter
E55&98 Jeep
Thanks guys I think I'll just install the 74 ones I bought.
post #6 of 7 Old 10-25-2019, 06:22 PM Thread Starter
E55&98 Jeep
Installed the PC74 bulbs in the cluster and climate control worked out great.
post #7 of 7 Old 10-25-2019, 06:42 PM
Spamoo123
Local parts yard will sell them cheap. Grab a handful out of old wj clusters. They are easy enough to pull pretty quickly.
Spamoo123 is offline
