I may have overfilled my transmission, 3/16ths above cold mark, did I? - Page 4 - JeepForum.com
 9Likes
post #46 of 52 Old 01-22-2020, 07:23 AM
2oldjeeps
tune in to the tranny nanny ,daily episodes right here on ye old forum...
99wj,143,000 miles
00xj,177,000 miles
10hummer3,74,000 miles
98xj,130,000 miles
2oldjeeps is offline
post #47 of 52 Old 01-22-2020, 01:22 PM
Bigrigr
Bigrigr's Avatar
Originally Posted by caliskier View Post
Drove it for 30 min tonight, its about 2/3rds of the way between the top cold hole and bottom hot hole. So I added about 11 more ounces, will see what I get tomorrow. 7 quarts 25 oz.
Sounds like you just about have it nailed. After a ride like that you just want it in between the top and bottom "hot" marks. (closer to the top preferred) Well done!
'00LMTD-4.7l,242hd,D30,D44A,3.73's,True-trac front,Spartan rear,3"BBfront,2"BBrear,JK'sW/32's
Bigrigr is offline
post #48 of 52 Old 01-22-2020, 07:34 PM Thread Starter
caliskier
Ok, this is where I am at. Here in OKC it is 38 degree F this evening. Drove for 30 min again and closer to the right level but the transmission is not getting hot, the fluid on my hands is just warm and the pan is warm to the touch. Measured the fluid temp inside the transmission with my DMM temp probe and also used my IR temp sensor on the hot side of the transmission fluid line to the transmission cooler. Both temps read 126 degrees F. I pulled the 565RFE temp chart and plotted my measurements (cause that's the kind of guy I am) orange is where my fluid is, blue is where it should be for 126 degrees. I added 4 more oz, so 7 qts 29 oz.
caliskier is offline
post #49 of 52 Old 01-22-2020, 08:04 PM
Bigrigr
Bigrigr's Avatar
Damn Caliskier! You dont need our help, you just need a spreadsheet! Ha Ha. i think you are gonna be just fine! Only thing you needed was to know to check it while idling, i bet you never will forget that now. Lol
Bigrigr is offline
post #50 of 52 Old 01-22-2020, 09:14 PM Thread Starter
caliskier
Ha ha, thanks brother, yeah I am definitely learning about how these transmissions work. On my odyssey its really simple, drain 3.3 quarts, fill 3.3 quarts
post #51 of 52 Old 01-23-2020, 09:38 PM Thread Starter
caliskier
I think I am going to call it good and stop worrying about it.
post #52 of 52 Old 01-23-2020, 10:26 PM
Bigrigr
Bigrigr's Avatar
Yep, I think you can rest easy now. Time to move on to something else fun. Like a lift kit!
Bigrigr is offline
