I changed the valve cover gasket and screwed up my transmission - JeepForum.com
 4Likes
  • 4 Post By Ralph77
post #1 of 8 Old 04-01-2020, 02:27 PM Thread Starter
Purcell69
I've been spending more that the usual amount on the Green Weenie trying to get ready for summer. Yesterday I got the AC vacuumed down and charged after replacing a damaged condenser core.
Today, I replaced the valve cover gasket and in the process, I broke the end off the kickdown/throttle valve cable. I have tried a few different methods to create a makeshift repair, but none will let the transmission shift in to top gear and at the same time, I noticed the cruise control will not set. It comes on on the dash display, but won't set.
How bad am I screwed?
-Joe
Purcell69 is offline
post #2 of 8 Old 04-01-2020, 02:36 PM
Double E
Double E's Avatar
Only until you can get to a junkyard or fab up a solution with JB weld.
'04 Freedom Edition HO & '04 Overland HO (previous '00 Laredo 4.7)
Double E is offline
post #3 of 8 Old 04-01-2020, 03:37 PM Thread Starter
Purcell69
Cool. I was just looking at the bottom side of things. It doesn't look difficult to change out. I had it in my head that I'd need to open up the transmission to get to the bottom end of the cable. I can see that is not the case now. Thanks!
-Joe
post #4 of 8 Old 04-02-2020, 12:06 AM
Ralph77
In my travels I have come across this.
Not even sure if it is what you are talking about.
Apparently comes in different colors and metal I think.
So...........
https://www.shapeways.com/product/V9...tle-valve-clip
Ralph77 is offline
post #5 of 8 Old 04-03-2020, 01:41 PM Thread Starter
Purcell69
So...........
I saw one they make for the XJ Cherokee and started to order it, until I realized it was for the XJ.. I didn't find the one they make for the WJ and just ordered a new kickdown cable instead. I've been having issues with the transmission down shifts with the cruise control on anyway, so I ordered a solenoid kit and decided to do the whole shot at once.
That is great info for the next guy though, and the folks at Shapeways are wonderful. Like I said, I had ordered the wrong part, realized it after placing the order, and contacted them to cancel my order. They refunded my payment the following business day, no questions asked.
-Joe
post #6 of 8 Old 04-03-2020, 01:47 PM
Ralph77
-Joe
I have seen both and always wondered what the difference is.
Guessing that a 4.0 XJ throttle body would be the same as a WJ 4.0 throttle body but what do I know. LOL.
Ralph77 is offline
post #7 of 8 Old 04-04-2020, 05:56 AM Thread Starter
Purcell69
The XJ specifies a shorter plastic body. I've got both vehicles so I can verify there is a difference. I'd just hate to wait a few weeks for one to be made, only to find out the difference IS important. Shapeways doesn't have a stockpile of these. They take orders and print them as needed. Of course, they print other items too, so it depends on where your order falls in line.
-Joe
post #8 of 8 Old 04-08-2020, 03:44 PM Thread Starter
Purcell69
Well, I replaced the kickdown cable the other day, but it didn't fix the way the Jeep was running. I was having issues with the transmission not shifting in to overdrive and the torque converter not locking. Also, the cruise control would turn on, but would not engage.
As the sun fell, I found the cause. I was getting multiple Check Engine codes, (P0123, P0300, P0304, P0306 and P1494). I knew about the emissions code. I had a rotten elbow to the intake manifold that needed replaced, so I had capped the port until I could source a 1/4" replacement elbow. The misfires on cylinders 4 and 6 were new, but the engine was running smoothly, so I attributed those to old spark plugs the PO had installed who knows when.
The TPS fail code was the kicker. When I was messing with the throttle body, the cold air intake the previous owner had popped off. I didn't realize it had broken the TPS until the other night. The plug was hanging off the throttle body at a 45* angle. When I tried to move it, it broke completely.
With a new elbow, TPS, and fresh Champion Copper spark plugs, the Jeep was running great with no engine lights. Everything worked like it should and all was right with the world, until today.
That begins a new thread.
-Joe
