How to remove front skid plate ? - JeepForum.com
 2Likes
post #1 of 23 Old 10-21-2021, 08:25 PM Thread Starter
Rylxmp
2003 WJ
Hi guys I have a 2003 Jeep Grand cherokee limited with the 4.7 HO. I was planning on replacing my radiator so i watched a YouTube video where this guy removed his without removing the front bumper and under his jeep he had this plastic plate that was attached with 4 rivet retainers. When I went to look under my jeep I saw that instead of the plastic plate like in the video, I had a metal skid plate that seemed to be attached on with bolts. Is there anyway i can remove this skid plate without having to take the bumper off ?
Rylxmp is offline
post #2 of 23 Old 10-21-2021, 10:55 PM
xcaliber81
xcaliber81's Avatar
Yes you can.
xcaliber81 is offline
post #3 of 23 Old 10-21-2021, 11:47 PM
GmanWJ
GmanWJ's Avatar
Yup. I have done it several times. Taking off is easy, putting back is somehow a problem but it does go back in.
2.5" OME HD & Bilsteins
Dual Batteries
Aux Trailer Hookups (4awg charging & backup cam)
GmanWJ is offline
post #4 of 23 Old 10-22-2021, 05:35 AM
mak_v8
mak_v8's Avatar
four bolts and the front skid plate falls down, it'an easy removal.
Bolts are located on the sides of the plate, two on the right and two on the left sides.
Here different wj skid plates:
Grand Cherokee WJ 4.7 V8 HO. m.y. 2002
mak_v8 is offline
post #5 of 23 Old 10-22-2021, 08:40 AM
AVR2
I've kept my skid plate off. Make it *so* much easier to change the oil filter.
AVR2 is offline
post #6 of 23 Old 10-23-2021, 01:04 PM
Delta0
I would remove mine too for the same reason, except it seems to be inviting misfortune.
Delta0 is offline
post #7 of 23 Old 10-25-2021, 07:47 PM
Golden-Arm
Golden-Arm's Avatar
i guess i better go buy one, and install it. i'd hate to be inviting misfortune to my ride.
Uphill Slow, Downhill Fast, Tonnage First, Safety Last!
Golden-Arm is offline
post #8 of 23 Old 10-25-2021, 09:49 PM
blueseasons1
I wasnt aware one needed to remove the skidplate to change the radiator.
blueseasons1 is offline
post #9 of 23 Old 10-26-2021, 12:21 AM
BigMateo
The front bumper cover also comes off super fast and easy too, it's really not a big deal if you had to take it off. Just 2 10mm bolts on either side and a few clips on the front you can pop out with a flat head screw driver, that's all there is to it really.
Delta0 likes this.
BigMateo is offline
post #10 of 23 Old 10-26-2021, 10:13 AM
Delta0
Gee Goldie,
I just love the way you roll your eyes
Delta0 is offline
post #11 of 23 Old 10-26-2021, 01:39 PM
cDee63
cDee63's Avatar
I removed one from a Blazer with a stump years ago.....
2004 Limited, 4.7 modded slightly, IRO 3" RockLink LA front, adjustable SA rear, Bilsteins, Addco bar, JKS disconnects. Coming attractions include 242hd, IRO SYE and Woods DS right after the new engine/trans..
1974 Ironhead Sportster, total custom
High speed, low drag
cDee63 is offline
post #12 of 23 Old 10-26-2021, 02:32 PM
Mr. Bitey
Mopar Nut
Mr. Bitey's Avatar
Once Upon a Time.... I liberated the oil pan and all of its contents with a stump on a 1980 Buick Century. Of course there was the matter of a brick on the gas pedal and no driver at the time of said liberation....
I removed the composite skid off my 2005 WK (3.7; RIP) after the first oil change. PIA to get at the drain plug, and it dumped oil all over the top of the skid. I never put it back on - it is probably still sitting in storage...
2004 WJ 4.7 N, daily driver
1967 Jeep J100 panel truck (a-rusted development)
1970 'Cuda, 340 4bbl (10.952et @ 123mph)
1972 Dart Swinger, Gen III 6.4l Hemi (11.223 @ 113mph)
1974 AMC Gremlin X, 440 6bbl (sold)
1975 Jeep Cherokee Sport 2-door (in progress)
Mr. Bitey is offline
post #13 of 23 Old 10-28-2021, 12:06 PM Thread Starter
Rylxmp
2003 WJ
I kinda gave up when I went out today to do it. I had no issue removing the first 2 bolts that sit towards the rear of the vehicle but the front ones were unreachable. I tried using a swivel thing with like 14 inches of extensions but still couldn't do it. I had the tow hooks blocking it aswell. How can I take off the front 2 without having to remove my bumper.
Rylxmp is offline
post #14 of 23 Old 10-28-2021, 12:52 PM
GmanWJ
GmanWJ's Avatar
You need a 15mm socket, a swivel thing, and like 14 inches of extensions. A long-handled ratchet and/or breaker bar may help. I had mine off 5 days ago doing this, also have the factory tow hooks.
If things are rusty, try some penetrating oil. Make sure you are twisting the correct (counter-clockwise) direction. Sometimes it helps to swear ... almost required when putting it back on.
Dual Batteries
GmanWJ is offline
post #15 of 23 Old 10-28-2021, 02:29 PM
Delta0
Use a hole saw to cut some holes in the bumper so you can tackle the bolts head on?
Delta0 is offline
