how many WJ use a dual steering stabilizer set up?? - JeepForum.com
post #1 of 30 Old 04-08-2010, 03:03 PM Thread Starter
bikkerdude
bikkerdude's Avatar
how many WJ use a dual steering stabilizer set up?? what set up are you running? post some pics if you can. are you running that set up to cure Death wobble..
I am currently dealing with the whole Death Wobble problem and it is a pain.
I have a 99 WJ 3.5" coils with 2" BB all 4 adjustable front control arms. upgraded steering stabilizer. bushings tie rod ends and drag bar all where checked out by a shop said they were in good shape.
what are some other areas to check.. with out just dumping parts into it
thanks guys.
ps I'm a noob on here
bikkerdude is offline
post #2 of 30 Old 04-08-2010, 03:30 PM
FlipFlop425
Do you have an adjustable track bar?
FlipFlop425 is offline
post #3 of 30 Old 04-08-2010, 03:42 PM Thread Starter
bikkerdude
bikkerdude's Avatar
no I just have the track bar relocator. my toe is in spec. Is that what the track bar helps adjust?
post #4 of 30 Old 04-08-2010, 03:47 PM
ArloGuthroJeep
Mr. Hyde!
ArloGuthroJeep's Avatar
2020 FSJ Gladiator
I'll bet your Jeep that your DW is caused from your Trackbar relocation thing-a-ma-jig. Who makes it? Ditch the relocator and get an adjustable trackbar.
'21 JT Rubicon Diesel
ArloGuthroJeep is offline
post #5 of 30 Old 04-08-2010, 03:52 PM
xJoshxx
xJoshxx's Avatar
2012 WK
x2 relocators blow.
Sold4" Hybrid lift TeraFlex coils IRO Adjustable LA's Jks tracbar 1.25spidertrax spacers 265/75/16 Dura-tracs
Originally Posted by moPowered View Post
The SRt-8's are a liberty design.
2011 WK2 ORA2 sold
2012 WK2 SRT8 - Current
99 WJ Limited Lifted.
2001 WJ stock 4.0 304k miles
xJoshxx is offline
post #6 of 30 Old 04-08-2010, 03:53 PM Thread Starter
bikkerdude
bikkerdude's Avatar
that's what I was thinking about doing. I'm unsure about the maker of the relocation part. and advise on the dual ss set up? something like iro dual set up or kevins offroad?
post #7 of 30 Old 04-08-2010, 03:58 PM
Bama_WJ
Bama_WJ's Avatar
Get an adj. track bar first before you go buy a dual SS kit. You probably won't even need the dual SS kit once you get an adj. track bar.
Daniel
Current Stable: 2001 WJ, 2006 WK, 2006 TJ, 2014 WK2
Bama_WJ is offline
post #8 of 30 Old 04-08-2010, 04:00 PM
FlipFlop425
pm Kolak he has a sale on jks adjustable track bar going on still I think.
post #9 of 30 Old 04-08-2010, 04:12 PM
ArloGuthroJeep
Mr. Hyde!
2020 FSJ Gladiator
I bought a dual-SS kit, but ended up just ditching the lower one (kept getting damaged by rocks) and running a single upper SS.
post #10 of 30 Old 04-08-2010, 04:37 PM
wonderbrd937
i have a dual ss setup and i love it. make sure get the adj. trackbar those brackets are garbage
99 WJ 4" SA lift
rolled fenders
35" bfg km2
tons of fabrication
wonderbrd937 is offline
post #11 of 30 Old 04-08-2010, 06:59 PM
gatorayde
gatorayde's Avatar
Relocate the SS with an HD one and be done. The lower is going to get ruined if you offroad. A single HD SS keeps my unbalanced 35's and sloppy steering box under control.
gatorayde is offline
post #12 of 30 Old 04-08-2010, 11:42 PM
PhantomWJ
PhantomWJ's Avatar
2003 WJ
I use a dual SS from Rough Country..I have no complaints...but you should ditch the TB relocator bracket and invest in a adj trac bar...i had to ditch my weak relocation bracket and went with adj trac bar to cure the "wobble wobble"...I can only assume that the dual SS helped...
PhantomWJ is offline
post #13 of 30 Old 04-09-2010, 12:21 AM
Bama_WJ
Bama_WJ's Avatar
Same here. I use the IRO kit.
Daniel
Bama_WJ is offline
post #14 of 30 Old 04-10-2010, 10:03 PM
MidniteSquirrel
Funny thing is, I'm in a similar boat that the OP is in. Running my 2.5" BB with the UC springs, I've had death wobble ever since. I've tossed in a JKS adjustable trackbar, tightened the steering box so it's not as sloppy, I'm only running 32's, and I know my tierods are good. The SS and tires are fairly new as well. I'm honestly at my wits end. So! Dual SS setup is in the mail and should be here soon to see if it helps fix the problem. I'll be able to let ya know in a week. As for the track bar relocator... Arlo is right, per usual. (I hate saying that... )
2002 WJ - I6
BB+UC 3.5" lift | K&N FIPK | Armor/Tow points |
265/75R16 Cooper Discoverer S/Ts
MidniteSquirrel is offline
post #15 of 30 Old 08-23-2010, 05:41 PM
wjjeep4x4
I have the OME heavy duty lift kit and JKS track-bar installed on my WJ and am getting death wobble like crazy. It's becoming more evident to me that it is not safe at all. I was on the highway towing and got DW in Omaha on my way back from Chicago to Denver and had to virtually stop...almost got rear ended.. I have replaced the CV joints, aligned front end, aligned track bar, changed tie rod ends, and currently have an OME steering stabilizer, but am still getting DW. Should I upgrade to the dual SS? Or does anyone else have any other solutions to my problem?
I love the OME kit and do not want to get rid of it, but if I can't figure it out I might go back to stock :/
1998 XJ Sport. RE 3.5" Superflex, 31x11.50x15 Dakota Futura A/T. HP D30 Front & 8.25 Rear, IRO SYE w/ds, Kargo Master Roof Rack, Cobra 29 WX ST.
1999 WJ Laredo 4.0: BACK TO STOCK, 255/70/16 Firestone Destination A/T, K&N Intake, OME Steering Stabilizer, Addco Rear Sway Bar
wjjeep4x4 is offline
Will he need a new steering stabilizer? BCav ZJ Grand Cherokee Forum 7 05-22-2011 10:12 PM
Dual Steering Stabilizer DenLor ZJ Grand Cherokee Forum 53 04-06-2011 11:19 AM
where to get a dual stabilizer bracket kit? ronsaun ZJ Grand Cherokee Forum 20 01-29-2010 06:19 PM
Does anyone make a dual Steering Stabilizer/Damper kit? mad_nigerian ZJ Grand Cherokee Forum 8 11-18-2007 02:23 PM
Iron Rock Dual Stabilizer Pics? mtnjam ZJ Grand Cherokee Forum 13 11-16-2007 05:18 AM
