how long can you safely drive with a purged AC system? - JeepForum.com
post #1 of 6 Old 08-01-2021, 10:35 AM Thread Starter
anarky321
Wj how long can you safely drive with a purged AC system?
im waiting at least another week for my manifold gauges and vacuum pump so right now its all air in there....can i safely drive it at all? with the AC off of course.....should i grab a bypass belt? im just worried about damaging compressor
2004 WJ 4.0L Freedom 4wd (daily)
2002 WJ 4.0L Laredo 2wd (backup)
anarky321 is offline
post #2 of 6 Old 08-01-2021, 10:41 AM
Soem0
Soem0's Avatar
You should be just fine so long as you don't turn on the ac or defroster.
Soem0 is offline
post #3 of 6 Old 08-01-2021, 10:46 AM
AVR2
Yeah, the compressor won't do anything. Unplug the clutch connection or remove the AC relay if you're that worried, but the pressure switch shouldn't let the clutch engage anyway.
AVR2 is offline
post #4 of 6 Old 08-01-2021, 12:09 PM
WJ60
WJ60's Avatar
If you know there are no leaks, you should disconnect the clutch connection, and put some nitrogen or CO2 in the system. The moisture that's in the air could possibly cause issues before you're able to get the vacuum pump on it.
'77 Chevy C10 pickup
'01 WJ 60th Anniversary Edition
'13 Dodge Dart Rallye
WJ60 is offline
post #5 of 6 Old 08-01-2021, 03:46 PM
AVR2
I had the AC system in my Ford Escape empty for nearly a month. I then did a regular vacuum and refill (didn't replace the O-rings or accumulator, because I'm in the UK and RHD accumulators simply don't exist for the Escape any more, it wasn't a popular vehicle over here and only sold between 2001-03) and almost 3 years later it's still working fine.
AVR2 is offline
post #6 of 6 Old 08-02-2021, 06:43 AM
LelandGray
I drove for like 2 years with a purged AC system.. Just make sure your compressor doesn't come on.
2001 WJ Limited w/ QuadraDrive
Bilstein 5125's
jgcparts 2.5"/2" BB
JK take offs & 265/75R17's
LelandGray is offline
