How do you deal with this brake line clip on the rear axle? - JeepForum.com
 4Likes
  • 2 Post By AVR2
  • 2 Post By HarryH3
post #1 of 8 Old 05-31-2020, 01:36 PM Thread Starter
AVR2
The brake hard line along the axle tube to the right rear wheel is held down by this clip.
Do you just pry it open to release the line and then bend it back when the new line's installed? That would seem to be the only way to do it, but I wanted to be sure...
AVR2 is offline
post #2 of 8 Old 05-31-2020, 02:26 PM
HarryH3
That's how I've always done it, but never with a clip that was that rusty.
HarryH3 is offline
post #3 of 8 Old 05-31-2020, 04:42 PM Thread Starter
AVR2
Worst-case, there are always zip ties
2oldjeeps and Klarah523 like this.
AVR2 is offline
post #4 of 8 Old 05-31-2020, 05:59 PM
HarryH3
Add some duct tape and bailing wire and you'll have a complete repair kit!
HarryH3 is offline
post #5 of 8 Old 05-31-2020, 06:35 PM
97Mule
97Mule's Avatar
Those clips are made to bend, just use a sdriver.... that's going to be the easist part of your project!
97Mule is offline
post #6 of 8 Old 06-01-2020, 05:01 AM
Klarah523
Klarah523's Avatar
On a previous vehicle I used some brake line clamps that were a rubber bushing that went around the line and tied to the axle with hose clamps. And I can't figure out where I got them. Internet image search hasn't been useful, so if anyone thinks they know what I'm talking about I'd appreciate a link.
I really need to have my stripped out vent block held on with something besides a couple of fat cable ties and some black RTV, though it's held.
2000 WJ (Laredo w/ 4.0L) =|||||||=
Klarah523 is offline
post #7 of 8 Old 06-01-2020, 05:04 AM
Klarah523
Klarah523's Avatar
I also throw in a roll of self-sealing repair tape and JB weld to complete the kit.
post #8 of 8 Old 06-02-2020, 01:47 AM
Uniblurb
Uniblurb's Avatar
If running new brake line w/o the spring protector I've pried up those welded on clips, split longways a short piece of small fuel hose on the line, then pushed the clip back down. I've also used small diameter split pieces of fuel hose elsewhere on the brake lines where they may rub against bare metal (over top of the pumpkin).
I've also used the below rubber cushioned clamps on brake and fuel lines. Of course you wouldn't be screwing it to axle but could probably run a zip-tie through the holes.
https://www.amazon.com/Allstar-Perfo.../dp/B003BZQ7EE
While it's a little pricey at $23 for 16ft I've also used the below stainless 3/16" protector (gravel guard spring) when making my own brake lines next to the axles.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Darn bushy-tailed rats have chewed up my trailer wiring again and I'm going to run all new wiring inside of the above stainless steel spring protector. Hope that dulls their little demon teeth! Lol.
2004 4.7L WJ Limited, 96 4.0 ZJ
Uniblurb is online now
