How do I tell if I have an up country suspension - JeepForum.com
post #1 of 12 Old 11-22-2019, 01:59 PM Thread Starter
JGCJeep
JGCJeep is online now
post #2 of 12 Old 11-22-2019, 02:22 PM
99wjtx
99wjtx's Avatar
It is build code AWE and it would also be listed on a build sheet generated from an online build sheet generator like this one:
https://fcacommunity.force.com/RAM/s/equipment-listing
Enter the VIN and check the result. It is also discussed at wjjeeps.com here:
http://www.wjjeeps.com/upcountry.htm
Rage! Rage against the dying of the Jeep.
99 WJ Limited 4.7/NP242
01 WJ Laredo 4.7/NP242
99wjtx is offline
post #3 of 12 Old 11-22-2019, 02:27 PM
jtpeters
Go to the above link and put in the last 17 characters or your VIN. Your suspension option should be listed on the Build Sheet.
2004 Jeep Overland WJ 4.7 H.O. (Bought new in Oct 2003)
2014 Jeep Overland WK2 5.7 Hemi (Bought used in 2016 w/7k miles)
1970 Ford Mustang Boss 302 (in Family since 1974)
2013 Ford Mustang Boss 302
2011 BMW 328i
jtpeters is offline
post #4 of 12 Old 11-22-2019, 04:26 PM
blueseasons
Upcountry suspension was a package and also included engine skid plate, tow hooks.
blueseasons is offline
post #5 of 12 Old 11-22-2019, 04:48 PM Thread Starter
JGCJeep
Thank you for the answers. 🙂
post #6 of 12 Old 11-24-2019, 09:25 AM
Mattyjm
Mattyjm's Avatar
I was under the impression that Quadra-Coil suspension, as notated by the factory, was regular suspension. My 2004 SE WJ came ordered with a trim package that included UC suspension, but the factory buildsheet states that it has Quadra Coil Suspension. So, I'm assuming the original purchaser deleted the UC spring option.
What's funny about that is, the buildsheet for my '04 RM Edition WJ lists it as having regular duty suspension, and not Quadra Coil.
So which is it? Is Quadra Coil the same as Up-Country or was there a third suspension option available?
2004 Special Edition WJ. LOADED!
2004 Rocky Mountain Edition. Froggy Bandit. Wife's Daily Driver. PRISTINE! Stock height and may stay that way.....
Mattyjm is offline
post #7 of 12 Old 11-24-2019, 12:00 PM
jtpeters
@MattYj im
I believe I read somewhere that there was no Up Country Suspension package available for the 2004 model year.
2011 BMW 328i
jtpeters is offline
post #8 of 12 Old 11-24-2019, 10:43 PM
DubJFTW
i believe that if you measure from the tire wheel well to the ground with up country suspension, you should get 19"1/2. i have it and it is on my build sheet. i read it here on the forums at some point. it was in a thread. i wish i could be more helpful.
DubJFTW is offline
post #9 of 12 Old 11-25-2019, 04:11 PM
Mattyjm
Mattyjm's Avatar
You must have meant wheel center to wheel well, because from the ground, my wheel well is about 34 inches or so....no where near 19 1/2". LOL... Wheel center to fender edge on both my '04 WJs is about the same. Near 18 1/2".
Neither WJ is sitting on flat, level ground right now because we don't have much of that around here. According to the UC write-up over at wjjeeps, as well as the piece about the 2004 Special Edition Laredo, UC suspension (but not the whole UC package) was offered at the 4WD "T" trim level. My '04 SE WJ has some parts of the "T" package, but not the whole "T" package. I believe the UC springs and shocks were deleted.
Mattyjm is offline
post #10 of 12 Old 11-25-2019, 07:16 PM
DubJFTW
you're correct, sorry about that. My build sheet list it as "Up Country Suspension Group(97-2-26)" i read in these forums that when you measure it it will be 19.5 from the wheel well to the hub. I checked mine and that is what i have. if yours is reading 18.5, makes sense that you have the regular suspension. i had to do some research too when i was wondering. it's been several years so sorry about saying it incorrectly.
DubJFTW is offline
post #11 of 12 Old 11-27-2019, 05:29 PM
CJREX
All WJs have Quadra-coil suspension.
It's a Jeep marketing term for 4 coil spring suspension.
As far as Up Country suspension, it was available on 2004 models built up until August 29 2003.
After that date the option simply disappeared.
My Overland is a 2004 built on August 28th 2003 so I just snuck in on the Up Country suspension by 1 day.
2004 Grand Cherokee Overland
2" BB with 255/70/17
Kolak exhaust
CJREX is offline
post #12 of 12 Old 11-28-2019, 06:30 PM
Rdfact
Thanks for those links - very informative. I have a stock 01 Limited and the build sheet shows the UC package. I have lots of skid plates under my WJ.
I measured from the bottom of the rear wheel well to center of the hub and get 19 1/4 (maybe mine is dropping a tad).
Rdfact is offline
