Hitch mounted spare tire carrier - JeepForum.com
 6Likes
post #1 of 26 Old 06-23-2021, 01:28 PM Thread Starter
Rdfact
Rdfact's Avatar
I searched the forum and found a few similar ideas but then found the below pic on Imgur and was hoping the owner is a member here and would chime in.
This looks like a hitch extension with vertical mounts welded on to hold the vertical square tubing that the tire mounts to. Swings down to allow the hatch to open. And you still have an open hitch receiver to use. I don't plan to tow with my WJ but do have a hitch recovery point.
Thought on this? Anyone have a similar setup, if so how well do they work?
ETA: My search was only in the WJ and XJ sections. I did not search the Fabrication section.
Rdfact is offline
post #2 of 26 Old 06-23-2021, 07:32 PM
Vaskania
Vaskania's Avatar
You're in luck. Here's the writeup: https://www.jeepforum.com/forum/f37/...hitch-4062306/
Bigrigr and UnekornPrincess like this.
'05 KJ Renegade 4x4 [RIP 12/28/2018]
'01 WJ Limited 4x4 4.7L
Vaskania is offline
post #3 of 26 Old 06-23-2021, 08:50 PM
sdg3205
sdg3205's Avatar
I have one. Personally I wouldn't recommend it if you use your trunk a lot. I have a dog, family and carry my tools in the spare tire well. I'm always in the trunk and I got tired of constantly swinging the tire up and down, especially in the rain and snow.
I just put it on for trips now and leave it off the rest of the time. I wired it for plate lamps which is cool.
sdg3205 is offline
post #4 of 26 Old 06-24-2021, 12:58 AM Thread Starter
Rdfact
Rdfact's Avatar
Thanks for that.
Rdfact is offline
post #5 of 26 Old 06-24-2021, 06:20 AM
Delta0
Hydraulic ram and pump?
Delta0 is offline
post #6 of 26 Old 06-24-2021, 06:22 AM
sdg3205
sdg3205's Avatar
Originally Posted by Delta0 View Post
Actually I thought about incorporating a lift piston. But for what it would cost to fabricate I could buy something better. I prefer the swing out options
Wyo likes this.
sdg3205 is offline
post #7 of 26 Old 06-24-2021, 07:27 AM
Delta0
Thanks
Delta0 is offline
post #8 of 26 Old 06-24-2021, 12:31 PM Thread Starter
Rdfact
Rdfact's Avatar
I started looking at some swing out options too. The couple I found you can buy were $1,000 - $1,500
Not sure I have the skills or tools to build something like that myself. But I may try anyway.
Rdfact is offline
post #9 of 26 Old 06-24-2021, 12:36 PM
sdg3205
sdg3205's Avatar
Apparently the early 2000s Jimmy swing out carrier can be modified to fit out jeeps. And theyre cheap!
sdg3205 is offline
post #10 of 26 Old 06-24-2021, 06:23 PM
Golden-Arm
Golden-Arm's Avatar
just throw the spare on the roof. get a bike lock to secure it.
Uphill Slow, Downhill Fast, Tonnage First, Safety Last!
Golden-Arm is offline
post #11 of 26 Old 06-24-2021, 08:21 PM
Bigrigr
Bigrigr's Avatar
Thanks for finding that write-up Vaskania. This has peaked my interest.....
Vaskania likes this.
'00LMTD-4.7l,242hd,D30,D44A,3.73's,True-trac front,Spartan rear,4" short arm lift,JK'sW/32's
Bigrigr is offline
post #12 of 26 Old 06-26-2021, 01:45 PM
carlsondrew3
carlsondrew3's Avatar
If you want a pre-built option look up Rigid-Armor. A bunch of 4Runner/Tacoma guys I know have spoken very highly of the build quality on their carriers and the ease of use. They only make an option for Grand Cherokees 2005-2020 but from what I'm told it'll work just fine for the WJ's - price point ain't half bad either.
Drew C
carlsondrew3 is offline
post #13 of 26 Old 06-26-2021, 03:26 PM
underscore
I picked up one of these bike racks off someone for $60:
Right now my plan is to unbolt that top elbow, and attach one of these, but using ubolts to clamp it and one bolt straight through the rack so it can't slide down:
00 WJ
[x] 07 WK CRD/OME/MALONE 1.5 [x] 00 XJ/OME [x] 97 TJ [x] 92 YJ
underscore is online now
post #14 of 26 Old 06-26-2021, 07:53 PM
fhunziker
Im quite happy with my Wilco Offroad Offset Hitchgate. I can still open my rear window, and swing it away when I need to open the liftgate.
Sent from my iPhone using Tapatalk
fhunziker is offline
post #15 of 26 Old 06-27-2021, 02:25 PM
Bigrigr
Bigrigr's Avatar
That ones good looking too, I was pondering how to flip the other setup around so I could still flip up the glass without moving the tire....
Bigrigr is offline
