HighBeam Light Bar splice - JeepForum.com
 1Likes
  • 1 Post By GeoffPeterson
post #1 of 5 Old 12-10-2019, 09:36 PM Thread Starter
jeepdewey
Has anyone wired there light bar to there HighBeam switch, I want it as simple as possible . I'm trying to have it so I don't need a new switch and I can use the highbeams switch as a switch for the light bar.
jeepdewey is offline
post #2 of 5 Old 12-10-2019, 11:33 PM
SoCal2004wj
SoCal2004wj's Avatar
I imagine you could activate the light bar by tapping into the high beam relay. However, it may cause problems since the relay and fuse were never intended to carry the load for both the high beams and the light bar. I would just wire a separate switch, relay, and fuse. It's only a flick of a switch.
SoCal2004wj is offline
post #3 of 5 Old 12-10-2019, 11:50 PM
underscore
2007 WK
Tap into the high beam and use that as the power source for a switch. Have that switch trigger a relay and have that relay drive the light bar. Then when you need to switch off the high beam and the light bar all you have to do is pull the normal arm, but the light bar doesn't have to be on every time the high beams are on.
If for whatever reason you do always want the light bar on with the high beams just have the high beam wire trigger a relay that supplies power to the light bar.
07 WK CRD//QDII//OME MD//MALONE 1.5//OMG WTF BBQ
underscore is offline
post #4 of 5 Old 12-11-2019, 06:38 AM
HarryH3
Check out the wiring diagram near the bottom of this page: https://ck5.com/forums/resources/wir...ing-lights.36/ The factory wiring colors are probably different, since that project was on a Suburban, but the switch and relay wiring will be the same. Just connect your light bar to the "driving lights" circuit in the diagram.
HarryH3 is offline
post #5 of 5 Old 12-11-2019, 06:12 PM
GeoffPeterson
2003 WJ
I'm wiring my driving lights that way. Connect the relay trigger to the high beam fuse (either left or right side) using one of these piggyback fuse connectors. DON"T wire your lights up directly without using a relay.
https://www.walmart.com/ip/2-Add-A-C...20fuse&veh=sem
Reech likes this.
GeoffPeterson is offline
