Help with another brand... - JeepForum.com
 2Likes
  • 1 Post By WJ60
  • 1 Post By 222Doc
post #1 of 6 Old 09-21-2021, 07:05 AM Thread Starter
cDee63
cDee63's Avatar
I know this may be blasphemy but are there any Subaru knowledgeable here? In particular an Outback 2016 variety. A good friend has one and I am getting ready to do some suspension work on it, a small lift. Looking for any tips from those who know these things. Thanks!
2004 Limited, 4.7 modded slightly, IRO 3" RockLink LA front, adjustable SA rear, Bilsteins, Addco bar, JKS disconnects. Coming attractions include 242hd, IRO SYE and Woods DS right after the new engine/trans..
1974 Ironhead Sportster, total custom
High speed, low drag
cDee63 is offline
post #2 of 6 Old 09-21-2021, 10:30 AM
darkstarmoto
I'm a bit of a Subaru wrench. The lift on these is usually a spacer kit, space down the struts and a drop kit for the rear subframe. Speaking of subframe...make sure the 4 bolts can be loosened before starting. They have a tendency to get rusty and are a bear to get out.
Here's some decent instructions from a kit. https://installguides.s3.ca-central-...9_installguide
darkstarmoto is offline
post #3 of 6 Old 09-21-2021, 11:24 AM
mak_v8
mak_v8's Avatar
this is not a real lift, but everything depends upon real needs: https://www.spaccer.com/en_IE/system...spiral-springs
Grand Cherokee WJ 4.7 V8 HO. m.y. 2002
mak_v8 is offline
post #4 of 6 Old 09-21-2021, 12:10 PM Thread Starter
cDee63
cDee63's Avatar
I was referred to ReadyLift SST kit. Says it will fit a 245/65-17 tire with +38 offset wheel without messing with the cradle due to their offset bushings, seems to have good reviews overall. The tire size allowed would be perfect for her, this rig will be for fire roads and light trailing in Northern Michigan. No mud bogging or rock crawling. I am gathering all the suspension parts front and rear now as well as CV shafts, struts, etc.
cDee63 is offline
post #5 of 6 Old 09-21-2021, 05:00 PM
WJ60
WJ60's Avatar
BLASPHEMY!!! Off with his head !!!!!
cDee63 likes this.
'77 Chevy C10 pickup
'01 WJ 60th Anniversary Edition
'13 Dodge Dart Rallye
WJ60 is offline
post #6 of 6 Old 09-21-2021, 05:17 PM
222Doc
222Doc's Avatar
here i thought they were going 37s.......... hey some built this out of a Fiat 500... anything is possible.
cDee63 likes this.
222Doc is offline
