Grinding noise from center console when braking...help! - JeepForum.com
post #1 of 6 Old 05-24-2013, 10:23 AM Thread Starter
jessejames
I checked the universals for the 4wd and the rear universals. All fine.
I checked the brakes and found the LF caliper had one piston sticking and the wheel turned hard. Aha...here it is.
Ah no.
New caliper and I still have that noise.
Any ideas? I'm lost.
jessejames is offline
post #2 of 6 Old 05-24-2013, 10:26 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
Year, engine, transfer case, trim level.
Please fill in your jeep information so we can help.
ratmonkey is offline
post #3 of 6 Old 05-24-2013, 10:29 AM
nstevic01
Check the transmission cable that hangs over the front driveshaft. The clip that holds it in commonly breaks and will cause the cable to rub against the shaft during braking making a noise.
99 WJ with a 4.0l and Selec-Trac; 01 WJ with a 4.0l and 2wd
nstevic01 is offline
post #4 of 6 Old 05-24-2013, 02:56 PM
derekmac
derekmac's Avatar
+1 That happened to mine as well. Zip tied it up and no noise since.
2005 TJ Rubicon
derekmac is offline
post #5 of 6 Old 05-25-2013, 12:23 PM Thread Starter
jessejames
Wj 2002 WJ select trac
Thanks for that cable clip info.
The grinding is the Rotating type of noise. When I checked the universals I saw no cable hanging. Do you guys mean when you say the 'front drive shaft' - what I call 4wd transfer case out put shaft? or something else?
post #6 of 6 Old 05-27-2013, 11:46 PM Thread Starter
jessejames
Thanks a wire tie did it!
