Griffen Combo radiator/ fan, relay or factory wiring? - JeepForum.com
post #1 of 5 Old 07-17-2021, 10:10 PM Thread Starter
Nkmaynard
I just bit the bullet and installed a Griffen Combo radiator in my 2000 WJ 4.0. Should I just power the aftermarket fan with the factory fan circuit or install a relay? Thoughts?
Nkmaynard is offline
post #2 of 5 Old 07-20-2021, 06:16 AM
snowbuggy
I think the factory wiring already has a relay.
snowbuggy is offline
post #3 of 5 Old 07-22-2021, 01:38 PM
leadsled jeep
leadsled jeep's Avatar
I’ve had a Griffin Radiator in my Fox body Mustang for 25yrs. I always use distilled water and antifreeze concentrate and there’s no sign of any corrosion etc at all after this long. Good purchase.
'02 4.7HO 235k ml. 2.5" BDS. Aftermarket arms & Addco sways. 245-70-17. Stock engine/tranny. Amsoil
leadsled jeep is offline
post #4 of 5 Old 07-22-2021, 06:04 PM
Golden-Arm
Golden-Arm's Avatar
screw the factory relay. (leave it hooked up, but don't connect it to any fan) get a new power source, and run a stand alone relay. solder your terminals, and run some large gauge wires (10 gauge strand). get a decent ground as well. stay far, far away from the factory garbage.
Uphill Slow, Downhill Fast, Tonnage First, Safety Last!
Golden-Arm is online now
post #5 of 5 Old Yesterday, 10:57 AM
leadsled jeep
One thing I’ve learned about Jeep’s are you can count on the factory wiring / electrical system to fail badly sooner or later. Mechanically they seem quite good but man did they cut corners on electron delivery.
