GM 75mm throttle body - JeepForum.com
 5Likes
post #1 of 22 Old 06-06-2018, 12:01 PM Thread Starter
xcaliber81
xcaliber81's Avatar
Anyone that's interested, I watch all this guys wj videos does great work.
xcaliber81 is offline
post #2 of 22 Old 06-08-2018, 11:04 AM
Brallen86
Brallen86's Avatar
2003 WJ
I saw this yesterday, I watch a lot of his videos as well, interesting and quality work. If only I could find a 08 manifold that doesn't break the bank
Martin Quandel likes this.
-03 WJ Limited - 4.7L, SC 91 Tune, 8.5" XeroFab/IRO Hybrid LA
-98 ZJ Limited - RIP
Brallen86 is offline
post #3 of 22 Old 06-08-2018, 08:05 PM
USMCWO97
USMCWO97's Avatar
Martin does incredible stuff with his WJ. I was impressed with his ram air hood fabrication.
USMCWO97 is offline
post #4 of 22 Old 09-30-2019, 10:34 PM
Martin Quandel
Thank you! I do appreciate that.
USMCWO97 likes this.
Martin Quandel is offline
post #5 of 22 Old 09-30-2019, 10:39 PM
Martin Quandel
Thank you!
Should start seeing the 08 intakes in the salvage yards soon. You can find them on ebayfor around $150.00 Salvage yard price $37.00 at the local Pic-a Part.
post #6 of 22 Old 10-01-2019, 08:43 AM
2oldjeeps
what is the purpose of this mod? what does it actually do?
99wj,143,000 miles
00xj,177,000 miles
10hummer3,74,000 miles
98xj,130,000 miles
2oldjeeps is offline
post #7 of 22 Old 10-07-2019, 08:24 PM
Spyder62
Spyder62's Avatar
I’m a fan as well. Thank you for the videos Martin! You make my life a little easier!
Spyder62 is offline
post #8 of 22 Old 10-09-2019, 12:18 AM
rep-tile
Cash 4 clunkers survivor
rep-tile's Avatar
It increases airflow. More airflow means you can burn more fuel (as computer adjusts fuel ratio). This means better performance.
04 WJ 4.0 - Avital 4103, DB-ALL
91 XJ 4.0 - Avital 4103, Stage-2 aFe intake system, BBK high flow Throttle Body, 703s injectors, Jones Exhaust A3518M-5
rep-tile is online now
post #9 of 22 Old 10-09-2019, 09:23 AM
2oldjeeps
i suppose if you are racing at 5000 rpm! only at wot...
do the same by modifying linkage to open stock tb faster. a lot less work...
fuel ratio is always the same...
97Mule likes this.
99wj,143,000 miles
00xj,177,000 miles
98xj,130,000 miles
post #10 of 22 Old 10-10-2019, 12:07 AM
rep-tile
rep-tile's Avatar
As you stated, fuel ratio is always the same. More air = more fuel to burn, with respect to ratio.
It's also less restriction to air flow, meaning your engine has to work not as hard to pull it. Has nothing to do with throttle response.
post #11 of 22 Old 10-10-2019, 05:23 AM
Oktavius
Modifying the linkage will not produce more power though. Will only make the gas pedal more touchy (which may be undesirable in precarious offroad situations). There are times when more power is desired other than racing. Towing is a big one. Also countering typical Jeep mods like increased weight from armor, gear, and large tires.
Fuel ratio will be the same. Benefit of modern fuel injection and O2 sensors.
Oktavius is offline
post #12 of 22 Old 10-10-2019, 08:25 AM
2oldjeeps
you wont get more power with bigger tb,only touchy pedal. exactly like linkage adjustment.
think it through,its a matter of how much air you let in with pedal push!!
if you got more free power they would make 6 inch tb...
like k n n air intake saying 5 hp gain, but at 5000m rpm where nobody drives,,,very long!
99wj,143,000 miles
00xj,177,000 miles
98xj,130,000 miles
post #13 of 22 Old 10-10-2019, 01:38 PM Thread Starter
xcaliber81
xcaliber81's Avatar
Do you have intrest in this modification or are you just trying to debate something you might not understand?
post #14 of 22 Old 10-10-2019, 02:43 PM
2oldjeeps
prove me wrong.
the two can let in the exact same air at different pedal positions. whats to understand??!!
the big one will "feel" faster or snappier and at wot may ? go a little faster.
show some dyno results side by side.
people make claims, like k n n with their cai,not worth the money...
99wj,143,000 miles
00xj,177,000 miles
98xj,130,000 miles
post #15 of 22 Old 10-11-2019, 07:59 AM
Frambo
I don't understand this but I'm definitely interested in this debate.
I don't claim to know anything about anything but so far 2oldjeeps argument seems straightforward to me
Is he wrong?
Frambo is offline
