Gauge face swap - JeepForum.com
 3Likes
post #1 of 18 Old 05-06-2021, 03:44 PM Thread Starter
smokeyyank
smokeyyank's Avatar
Gauge face swap
Question, I made a pit stop to the JY today and found a 01 limited with white face gauges and snagged it. I'm trying to confirm if I can swap the gauge face to my 04. I know I can't swap the entire cluster( at least I don't think) but according to wjjeeps the face's can swap. Just wondering if it's been done? I've searched but haven't really got any clear answers.
http://www.wjjeeps.com/gauges.htm
04 WJ, 4.7HO
3" IRO lift, fastman TB, 32s, lunchbox rear 242HD, 3" exhaust
smokeyyank is offline
post #2 of 18 Old 05-06-2021, 05:31 PM
Golden-Arm
Golden-Arm's Avatar
swap it. it's a bolt-in, plug and play set-up. did you power it up first, to see if it worked? also, look at the miles. the miles are stored in the cluster. a 250K mile cluster is going to bum you out, if you have a 100K mile ride. one of those cheap, cigarette lighter battery jumper packs is perfect for powering up a jy car, to verify lights, wipers, motors, cluster, seats, etc, before you waste time and money pulling them out.
Uphill Slow, Downhill Fast, Tonnage First, Safety Last!
Golden-Arm is offline
post #3 of 18 Old 05-06-2021, 05:53 PM
xcaliber81
xcaliber81's Avatar
04 will have a dummy oil pressure Guage while the 99 to 03 will show you the exact oil pressure.
xcaliber81 is online now
post #4 of 18 Old 05-06-2021, 06:28 PM
JoMc67
On FleaBay...You can get two different type aftermarket white face gauges for your WJ, depending on the year.
I was going to go the above route, but decided to get the stainless rings instead.
JoMc67 is offline
post #5 of 18 Old 05-06-2021, 07:17 PM Thread Starter
smokeyyank
smokeyyank's Avatar
Thanks for the info. Didn't power it up so guess I'll see if it works. Mileage doesn't bother me. Most everything has been replaced or rebuilt including engine. I'll maybe good with it tomorrow and see.
04 WJ, 4.7HO
post #6 of 18 Old 05-08-2021, 10:04 AM
Golden-Arm
Golden-Arm's Avatar
i got a set of white face gauges from an overland. when i rip out the dash to do the hvac system rebuild, i'm throwing it in. i lucked out, and found a set that was only 4k miles more than my factory 150k miles. score!
post #7 of 18 Old 05-08-2021, 10:32 AM
Bigrigr
Bigrigr's Avatar
Id like to try this swap, but the JY around here dont leave the keys in the Jeeps. Still wont be able to see the mileage.....
'00LMTD-4.7l,242hd,D30,D44A,3.73's,True-trac front,Spartan rear,4" short arm lift,JK'sW/32's
Bigrigr is offline
post #8 of 18 Old 05-08-2021, 11:56 AM
xcaliber81
xcaliber81's Avatar
I think you can power the cluster up to show the mileage it is stored in the cluster itself.
Bigrigr likes this.
post #9 of 18 Old 05-08-2021, 12:41 PM
Golden-Arm
Golden-Arm's Avatar
yeah, you can snag a harness from another wj, and use the mini jump pack to power up the cluster. will let you see miles and check that it lights up.
cDee63 and Bigrigr like this.
post #10 of 18 Old 05-12-2021, 02:22 PM
wjkeith
wjkeith's Avatar
Iíve done this on mine and itís a straight swap. No issues other than mileage difference.
wjkeith is offline
post #11 of 18 Old 05-17-2021, 06:27 PM Thread Starter
smokeyyank
smokeyyank's Avatar
Just to close the loop. Swapped the gauge cluster today and except a 40k mileage difference and air bag light staying on works fine.
04 WJ, 4.7HO
post #12 of 18 Old 05-17-2021, 08:10 PM
Golden-Arm
Golden-Arm's Avatar
i got mine done today too.
post #13 of 18 Old 05-18-2021, 11:14 AM
JoMc67
JoMc67 is offline
post #14 of 18 Old 05-19-2021, 02:11 PM
UKXJ
1997 XJ Cherokee
Location: The Smoke, The English Riviera - or somewhere in between
Must be just me who prefers the black gauges by far - in fact I would've considered swapping out the white ones on my Ltd had I kept it.
UKXJ is offline
post #15 of 18 Old 05-19-2021, 02:59 PM
BeetleCamry
BeetleCamry's Avatar
Guys you can swap JUST the faces by taking apart the cluster. Not talking about removing the needles (can't be done) I'm talking about the faces through the back of the cluster.
2004 Grand Cherokee Special Edition / Quadra-Trac-2 / Midnight Blue Pearl
BeetleCamry is offline
