Fuel Filter - Once and For All - JeepForum.com
View Poll Results: When DO YOU THINK one should you replace the WJ external fuel filter/regulator?
Only once a related problem or issue surfaces 43 17.27%
On some kind of maintenance schedule (intervals) 206 82.73%
Voters: 249. You may not vote on this poll
post #1 of 481 Old 08-16-2010, 01:56 PM Thread Starter
00JGC00
Wj Fuel Filter - Once and For All
(FYI, I'm talking about the external fuel filter/regulator, not the in-tank filter)
Ok, I've read as many fuel filter threads on here as I could find and I know that wjjeeps (or Chrysler, rather) says you should only replace the fuel filter as needed or once there is a problem. I've seen plenty of people on here who seem to disagree with that notion stating that if a filter is good for the life of a vehicle, it must not be doing a very good job filtering.
So what's your opinion? Do what the manufacturer says and wait till you have a problem before replacing the filter, or do you replace on some kind of regular maintenance schedule?
If you think it should be done on a regular basis, please indicate what kind of interval you think is best.
"The" Matt | '00 Limited WJ | "The White Wolf" aka "Willow" aka "Cool Whip" aka "Sweet 'N Low" aka "AKA"
Utah JeepCrew #39 | Club Matt #1
December '11 GCOTM | Build: https://www.jeepforum.com/forum/f197/life-times-979511/
00JGC00 is offline
post #2 of 481 Old 08-16-2010, 01:58 PM
xJoshxx
xJoshxx's Avatar
2012 WK
i changed my stock fuel filter at 120k gained an instant 2mpg from it.
IMHO i would replace every 30k
Sold4" Hybrid lift TeraFlex coils IRO Adjustable LA's Jks tracbar 1.25spidertrax spacers 265/75/16 Dura-tracs
Originally Posted by moPowered View Post
The SRt-8's are a liberty design.
2011 WK2 ORA2 sold
2012 WK2 SRT8 - Current
99 WJ Limited Lifted.
2001 WJ stock 4.0 304k miles
xJoshxx is offline
post #3 of 481 Old 08-16-2010, 05:27 PM
metalhead
2011 WK
I have been thinking about changing mine. Have close to 111,000 miles. They are expensive though. So I would think since people are driving these things well past 100,000 miles that at 100,000 it may be a good idea to change it.
metalhead is offline
post #4 of 481 Old 08-16-2010, 05:41 PM
lloyd877
lloyd877's Avatar
I just picked a WIX up for $35 at my local Baxter Auto Parts. Not that bad of a price. I will change it tonight and be driving 300 miles north tomorrow so I will see what happens. Oh yeah and I have almost 50K on mine.
WJ 2001 4.0L
5.9 ZJ AKA Race Jeep 30" BFGoodrich ATs (Sold)
lloyd877 is offline
post #5 of 481 Old 08-16-2010, 05:53 PM
straty1987
let us know how it goes.
my wj is at 44K and never thought of changing it
wjjeeps say not need to do regularly
but looks simple to do Jeep Grand Cherokee WJ - Fuel filters
i see autozone has a champion version for $30
straty1987 is offline
post #6 of 481 Old 08-16-2010, 05:56 PM
lloyd877
lloyd877's Avatar
It looks way simple to do, five minute job.
WJ 2001 4.0L
lloyd877 is offline
post #7 of 481 Old 08-16-2010, 06:06 PM
straty1987
just make sure not to have a smoke while you do it
post #8 of 481 Old 08-16-2010, 06:25 PM
lloyd877
lloyd877's Avatar
Probably a good Idea. I don't smoke anyways.
WJ 2001 4.0L
lloyd877 is offline
post #9 of 481 Old 08-16-2010, 09:35 PM
SplitNail
SplitNail's Avatar
DONT USE THE AUTOZONE ONE!! MINE FAILED TODAY!! For real its crap.
If it was just a filter I wouldnt care but its also the regulator. Got mine from the dealer for $77. Cant go wrong. Got the new one in and it worked like a champ!
1999 WJ 4.7L V8, 242 TC, Front Aussie Locker, 4 Inch RC X-Series lift, 17x8 w/ 4.5BS Black Rock Vipers, 285/70/R17 BFG KM2's, All AMSOIL Synthetic Fluids
SplitNail is offline
post #10 of 481 Old 08-16-2010, 10:19 PM
straty1987
good to know then, thanks.
might look up the wix one
post #11 of 481 Old 08-16-2010, 10:34 PM
lloyd877
lloyd877's Avatar
I attempted the removal and install but could not get all the little hoses off. I might just take it to a shop and have them do it.
WJ 2001 4.0L
lloyd877 is offline
post #12 of 481 Old 08-16-2010, 10:39 PM
SplitNail
SplitNail's Avatar
Oh come on... It takes a little time. Don't wuss out. Look this over and try again. The one that is all metal, I used a 7/16 inch open ended wrench to push in the clip and then once its in pull the hose off.
http://www.wjjeeps.com/misc/quick_connect.pdf
post #13 of 481 Old 08-16-2010, 10:43 PM
Farlander
I just did this job myself -- it is a REAL PIA no doubt. Don't be discouraged though -- they are actually easy if you know what to do. Ok, there's 3 hoses right? Two on the left and one on the right. Well to get the 2 off with the white plastic clips, you have to insert a round sleeve in between the junction to spread the clip tabs and the lines will come apart. Since this is nearly impossible to do, don't waste your time, instead cut the filter off with a pair of dykes as close to the filter housing as possible, leaving yourself as much protruding line as possible. Then, take two little screwdrivers (or a fuel line removal tool if you can find one, occasionally they're included with the filter) and stick them up in between the line/hose. Pop the two tabs of the white plastic clip. Use a pair of pliers or vice grips to pull the old filter line out. The third hose was the trickiest for me -- I didn't realize until a mechanic walked over and did it in 2 seconds that you actually squeeze the black part of the line, and pull the line straight out -- you still have to release from the white clip inside the hose but it's not even necessary to save this one. Be very careful though, would hate to have to change those hoses JC. Smoking recommended.
Farlander is offline
post #14 of 481 Old 08-16-2010, 10:47 PM
SplitNail
SplitNail's Avatar
Thats way complicated. Just stare at it. It will make sense. Dont pay $100 to have someone do it. Give me $100 for the advice
post #15 of 481 Old 08-16-2010, 11:05 PM
lloyd877
lloyd877's Avatar
I will Do it myself I just leave early tomorrow and don't want to end up breaking something tonight so I will try it again when I get back from my trip.
WJ 2001 4.0L
lloyd877 is offline
Whistling Fuel Filter SplitNail WJ Grand Cherokee Forum 46 10-09-2010 06:15 PM
fuel filter help pjkatz04 WJ Grand Cherokee Forum 9 08-07-2010 10:03 AM
What Fuel Filter to get ljhopp WJ Grand Cherokee Forum 15 08-05-2010 09:24 AM
Fuel filter change Fishinmission WJ Grand Cherokee Forum 11 03-15-2010 10:55 AM
fuel filter TotalJeep WJ Grand Cherokee Forum 1 01-10-2004 07:08 AM
