Front Spring Mount/Perch Rusted - JeepForum.com
post #1 of 5 Old 05-23-2020, 03:37 PM Thread Starter
justin_mac12
So I was installing a 2.5 in spring coil lift kit and the front spring mounts/perches are rusted and unsafe to put the stiffer springs. Should I just weld a new steel spring mount or get a dana 30 junkyard axle?
justin_mac12 is offline
post #2 of 5 Old 05-23-2020, 03:59 PM
coldspit47
If you can weld and can get a new perch it seems to be a no-brainer to me. Why go through the trouble of an axle swap if you can just weld in new perches.
04 WJ NV242, IRO 3in, bilsteins, IRO adj UCAs/LCAs/A arm, 265/75/16 Laufenn Xfit, 4.56 gears
coldspit47 is offline
post #3 of 5 Old 05-23-2020, 04:36 PM
helijeeper
helijeeper's Avatar
Weld in the new perches. That's what I did.
https://www.ironrockoffroad.com/prod...placement.html
That kit is $50 and well worth it imo. Simple and straight forward.
I had to weld those onto the axle I pulled from the junkyard. I'm not in the rust belt but those stock pieces just seem to rust off after a while.
Couple pics from when I did mine.
Sent from my SM-N960U using Tapatalk
"Fly Low, Take Chances"
2004 Grand Cherokee Laredo 4.0L Select Trac
helijeeper is offline
post #4 of 5 Old 05-23-2020, 04:44 PM
Spyder62
Spyder62's Avatar
I agree with coldspit .my son and I did mine.( He welded!) not a real big deal. If you have an open differential, I’d consider swapping out to one from a Quadra drive. But the perches on that might be just as bad as yours
Spyder62 is offline
post #5 of 5 Old 05-24-2020, 09:40 AM
sdg3205
sdg3205's Avatar
Yup. I got a nice set of varilocks off a wj with less than 56k miles. The bar codes and paper labels were still on the axles but the perches were totally rusted out. Not a rust belt car either. On the other hand my wj is a rust belt Jeep with almost 300k mikes and my perches are fine. Go figure.
sdg3205 is offline
