Front Side Indicator - JeepForum.com
post #1 of 8 Old 06-01-2020, 04:33 AM Thread Starter
ozzyjeep69
Hi, sorry guys really small, stupid question - 2004 GC, RHD, UK. How do I get the small side indicator / blinker assembly open / out of the front right wing (fender?) to change the bulb. I looked in the user manual and it says to use a small screwdriver, Ive tried that and the whole assembly seems to be looser, but its very dry and brittle, I dont want to crack it and break it. Does the entire unit pop out of the wing with a bit more force? Thanks
ozzyjeep69 is offline
post #2 of 8 Old 06-01-2020, 06:43 AM
Double E
Double E's Avatar
Can we get a picture? I'm thinking the US spec versions don't have this indicator. We only have the light that's integrated to the headlight assembly.
'04 Freedom Edition HO & '04 Overland HO (previous '00 Laredo 4.7)
Double E is offline
post #3 of 8 Old 06-01-2020, 09:11 AM Thread Starter
ozzyjeep69
Aha, if its unique to UK spec cars, then perhaps then that is why I can find virtually zero info about it..
post #4 of 8 Old 06-01-2020, 09:29 AM
Double E
Double E's Avatar
Yep...not a US-spec item.
I'm thinking it probably does come out with a wedge of a screwdriver blade. Any chance you can pull down the wheel well liner to see or push it out? Probably not a bad idea to flush that area out anyway once access is revealed.
Double E is offline
post #5 of 8 Old 06-01-2020, 09:33 AM Thread Starter
ozzyjeep69
Thanks, I didnt think about pulling the wheel liner - I think I'll do that rather than damage the paint or smash the plastic. Replacement parts aint cheap here in the UK - if you can get 'em. I'll report back in case anyone is interested!
post #6 of 8 Old 06-01-2020, 10:15 AM
HampshireWJ
HampshireWJ's Avatar
2003 WJ
There ya go - https://www.jeepforum.com/forum/f310...moval-1285941/
Think you need to get the wheel well liner out of the way, as well.
HampshireWJ is offline
post #7 of 8 Old 06-01-2020, 11:05 AM
Hudsonhawk59
I think you either push the lamp forward or backward (been a while since I took mine out) and then you should be able to use a screwdriver to pop the catch and it should then slid and lift out.
Hudsonhawk59 is offline
post #8 of 8 Old 06-02-2020, 02:39 AM Thread Starter
ozzyjeep69
Thank you for the info and link guys. Appreciated.
