Floor pans - JeepForum.com
post #1 of 13 Old 07-06-2020, 08:25 AM Thread Starter
slavo
Wj Floor pans
I know there has been some threads regarding floor pans for WJs. I was not able to find any good answer though.
Mine rusted out and I cannot find any replacement. Also there is no donors in my area to cut them out and weld them.
Do you know if there are any universal ones I could use or maybe from a different model? (not WJ) ? Also what's your opinion in using fiberglass cloth and resin for the repair.
slavo is offline
post #2 of 13 Old 07-06-2020, 06:31 PM
anotherheep
Is the under side as bad? Does it still feel somewhat solid or it crumbling through?
anotherheep is offline
post #3 of 13 Old 07-06-2020, 07:29 PM
2oldjeeps
did my 00 xj . gotta cut out all rust. i bought pan on ? net. layed them in a bed of seam sealer and bolted/screwed them in. sealed gaps under side...
gotta fix leaks too !!
Jeep Jeep-Grand Cherokee WJ Floor Pans | Jeep, Truck ...
www.morris4x4center.com › ... › Body & Frame › Body
Shop a wide range of Jeep, truck and SUV jeep-grand cherokee wj floor pans and related parts for your vehicle. Whether you're looking to repair or replace, find ..
99wj,143,000 miles
00xj,177,000 miles
10hummer3,74,000 miles
98xj,130,000 miles
2oldjeeps is offline
post #4 of 13 Old 07-07-2020, 06:56 AM Thread Starter
slavo
It is bad underneath. I cut one out which was a real chore. All four pans need to be replaced. Plus driver side front fender well
slavo is offline
post #5 of 13 Old 07-07-2020, 11:40 AM
2oldjeeps
my xj..
google wj pans
99wj,143,000 miles
00xj,177,000 miles
98xj,130,000 miles
post #6 of 13 Old 07-07-2020, 07:56 PM Thread Starter
slavo
what's that silver paint? it is por 15?
slavo is offline
post #7 of 13 Old 07-08-2020, 11:08 PM
Bigrigr
Bigrigr's Avatar
Damn 2oldjeeps! And i was nervous to cut out a 2 fisted size hole in my rocker panel to fix some rust. You had alot bigger job than that going on.....Just goes to show that anything is possible if the bones are good....
'00LMTD-4.7l,242hd,D30,D44A,3.73's,True-trac front,Spartan rear,4" short arm lift,JK'sW/32's
Bigrigr is online now
post #8 of 13 Old 07-13-2020, 11:02 AM Thread Starter
slavo
IT took me three days to prefarb a floor pan. Since the frame is in not a bad shape I decided to challenge myself and do it
slavo is offline
post #9 of 13 Old 07-13-2020, 10:00 PM
Bigrigr
Bigrigr's Avatar
not half bad!
post #10 of 13 Old 07-14-2020, 09:46 AM Thread Starter
slavo
Have a question. How to seal those welds from underneath ? It's close to the exhaust pipe and catalytic converter so I cannot apply regular seam sealant due to high temperature
slavo is offline
post #11 of 13 Old 07-14-2020, 04:18 PM
2oldjeeps
?, something like that,dont remember, took a month to clean hands...!
99wj,143,000 miles
00xj,177,000 miles
98xj,130,000 miles
post #12 of 13 Old 07-14-2020, 04:21 PM
2oldjeeps
i layed my pans in a bed of sealer to fill all spaces then screwed and bolted them solid. no welding..
99wj,143,000 miles
00xj,177,000 miles
98xj,130,000 miles
post #13 of 13 Old 07-29-2020, 06:53 AM Thread Starter
slavo
Final product:
I did it from one 18g metal sheet. All floor pans needed fixing. Other sections were replaced with 16g sheets. All welded. I used self etching primer and zinc primer for welding. After that, I used POR 15 for whatever I could protect against rust. Then, seam sealant and bedliner on top of that.
A hint for you guys, POR 15 loves zinc primers (those weld thru primers)
slavo is offline
