Finally! - JeepForum.com
 11Likes
  • 7 Post By jw11432
  • 1 Post By Mr. Bitey
  • 1 Post By mak_v8
  • 1 Post By jw11432
  • 1 Post By jw11432
post #1 of 9 Old 10-19-2021, 02:21 PM Thread Starter
jw11432
Finally!
After much time and work, my WJ is done. Just got my plates and registration sticker today after getting it inspected and going through rebuilt title process. I initially bought this Jeep (on a whim, actually) from an auction after it was deemed salvage, so I took a chance. Here's what has gone into it since October 2019:
•Pressure washed everything under hood before disassembling everything (but not before disconnecting battery!)
•Rebuilt cylinder heads (intake valve seats redone and peened in place, hydraulic lash adjusters cleaned and inspected, valve stem seals replaced, surface milled flat)
•Oil pump replaced
•Water pump replaced
•All engine seals replaced (minus rear main)
•All chassis grounds cleaned and/or replaced
•IAT sensor replaced
•Radiator replaced and upgraded to aluminum 2-row
•Hydraulic cooling fan replaced with e-fan and mech fan combo
•PS pump replaced with non hydraulic fan version and complete flush done
•Brake reservoir removed and cleaned, and brake fluid flush
•All 4 O2 sensors replaced
•All shocks/struts replaced (Monroe)
•All tie rod ends and steering damper replaced (MOOG)
•Fuel injectors replaced with upgraded 12-hole Denso remans (P/N: 12582704)
•New battery (cheapie for now, will replace with superior unit once this one fails)
•New battery cables and terminals
•Transmission filter change and fluid swap
•Rear diff fluid swap (2WD model)
•New fuel pump
•New fuel filter (WIX, seems ok so far)
•Oil change and filter of course
•HVAC (AZC) modified with LED bulb upgrade
•All HVAC actuators replaced (minus pass side behind assembly, I did the single-zone conversion)
•Backup camera added to aftermarket single DIN stereo, all wiring routed through roof and down A-pillar for completely invisible installation)
•New aftermarket headlights with LED conversions
•New fog lights
As for body work, I replaced the rear bumper cover and driver's side fender but repainted them along with repainting and fixing front bumper cover. Went ahead and added factory hitch (thanks Pick n Pull, super cheap!) and wiring for it as well. Gas tank skid plate also from that junkyard replaced and was had for very cheap.
I'm really quite proud of this, it took quite some time to get it all done, but I'm pretty happy with the results. Now I just need to drive it for awhile and make sure I like it or if I need to sell it and get something bigger LOL
CJREX, Mattyjm, zephyr424 and 4 others like this.
2004 GC Limited 4.7
jw11432 is offline
post #2 of 9 Old 10-19-2021, 02:24 PM
Mr. Bitey
Mopar Nut
Mr. Bitey's Avatar
Congrats! She looks good!
jw11432 likes this.
2004 WJ 4.7 N, daily driver
1967 Jeep J100 panel truck (a-rusted development)
1970 'Cuda, 340 4bbl (10.952et @ 123mph)
1972 Dart Swinger, Gen III 6.4l Hemi (11.223 @ 113mph)
1974 AMC Gremlin X, 440 6bbl (sold)
1975 Jeep Cherokee Sport 2-door (in progress)
Mr. Bitey is online now
post #3 of 9 Old 10-20-2021, 12:55 AM
zephyr424
1930 CJ2
Looks great!
zephyr424 is offline
post #4 of 9 Old 10-20-2021, 01:09 AM
tsetsaf
Wow looks great!
tsetsaf is offline
post #5 of 9 Old 10-20-2021, 03:47 AM
mak_v8
mak_v8's Avatar
looks brand new!
smokeythecat likes this.
Grand Cherokee WJ 4.7 V8 HO. m.y. 2002
mak_v8 is offline
post #6 of 9 Old 10-20-2021, 05:00 AM
Delta0
I bet you feel like a pup with 2 tails don't you JW?
Delta0 is offline
post #7 of 9 Old 10-20-2021, 09:57 AM Thread Starter
jw11432
Now that's a new one for me lol
But I'll probably go with yes. This has been 99% Sunday-only for the past 2 years, so it's almost surreal to finally be done. Of course, I have little things to do for interior, but nothing that's critical or particularly complicated.
2004 GC Limited 4.7
jw11432 is offline
post #8 of 9 Old 10-20-2021, 12:23 PM
Double E
Double E's Avatar
You might get an agreed-on insurance policy now that you have some coin and effort put into it. Not sure if an insurance company will do that for a salvage vehicle though.
If it gets the slightest accident damage, it will be totaled, again.
"We have it totally under control. It’s one person coming in from China. We have it under control. It’s going to be just fine." ~D. Trump, Jan 22, 2020.
Double E is offline
post #9 of 9 Old 10-20-2021, 03:56 PM Thread Starter
jw11432
Well before I could even get it inspected, I had to get it insured, so that was no problem. I did do the minimum required amount (plus uninsured motorist protection, that's a necessity), so certainly no illusions that this thing will be worth fixing should it get beat up again but I'm fine with that. I'd probably part it out at that point and help some other more worthy WJ's. As for the title, I got it rebuilt, so it's no longer considered salvage.
CraigMBAx likes this.
2004 GC Limited 4.7
jw11432 is offline
