Filling the axles. - JeepForum.com
 3Likes
  • 1 Post By LuthWJ77
  • 1 Post By xcaliber81
  • 1 Post By ksinglxj
post #1 of 15 Old 02-24-2020, 11:41 AM Thread Starter
xcaliber81
xcaliber81's Avatar
Filling the axles.
When you guys fill the axles what do you use to do it? Looking at pumps and such but what's best?
xcaliber81 is offline
post #2 of 15 Old 02-24-2020, 01:23 PM
LuthWJ77
LuthWJ77's Avatar
Gear oil normally comes with a little spout on the end I just put my finger over while turning it over to pour it straight in. Helps to have it jacked up some too to get sway bar etc out of the way. You could use a gear oil pump pretty easily too but it's not necessary.
Bigrigr likes this.
LuthWJ77 is offline
post #3 of 15 Old 02-25-2020, 01:19 PM Thread Starter
xcaliber81
xcaliber81's Avatar
That doesnt work in the back with the fuel tank and sway bar
post #4 of 15 Old 02-25-2020, 02:37 PM
FanTech
I have put a couple feet of hose over the spout (heat it up so it stretches easy) then you can tip the bottle over and squeeze. Takes while though.
I bet you could install a valve stem in the bottle, drill a hole in the cap, put a hose down the cap to the bottom of the bottle, pressure with a few psi.
FanTech is offline
post #5 of 15 Old 02-25-2020, 02:37 PM
sdg3205
sdg3205's Avatar
Youre right. Just drop the sway bar! it only takes an extra 5 minutes.
sdg3205 is offline
post #6 of 15 Old 02-25-2020, 03:24 PM Thread Starter
xcaliber81
xcaliber81's Avatar
And how about the fuel tank skid plate blocking you from tilting the the bottle?
I suppose I should I should remove that too?
2oldjeeps likes this.
post #7 of 15 Old 02-25-2020, 03:57 PM
ksinglxj
ksinglxj's Avatar
if you jack the frame up and let the axle stay on the ground, you can get enough of an angle to fill it. also depends on how much lift you have, and if you tilt your head the right way when you do it. slightly left, at a 17 degree angle is the ticket.
Bigrigr likes this.
ksinglxj is offline
post #8 of 15 Old 02-25-2020, 06:58 PM
LTopher
I just use a small hand pump. Only takes a minute or so to pump about 1L of fluid.
Programmers don't die, they just lose their memory!
His: 2001 WJ I6
Hers: 2011 WK2 V6
LTopher is offline
post #9 of 15 Old 02-25-2020, 08:36 PM
sdg3205
sdg3205's Avatar
Are you not asking for options in this thread? If you want to save your money, just tilt the bottle and squeeze. If you want an external pump, just get one.
Honestly this is an easy nut to crack. Iíll trade you Jeep problems!
sdg3205 is offline
post #10 of 15 Old 02-25-2020, 10:40 PM
Klarah523
Klarah523's Avatar
Seconded.
Been using the bottle pumps since my first car.
2000 WJ (Laredo w/ 4.0L) =|||||||=
Klarah523 is offline
post #11 of 15 Old 02-25-2020, 10:44 PM
Klarah523
Klarah523's Avatar
(Hit enter too soon)
I tend to buy my gear oil by the gallon, so the pump is way easier.
post #12 of 15 Old 02-25-2020, 10:50 PM
sdg3205
sdg3205's Avatar
Yeah thatís a good call. I tend to buy 3 or 4 of the royal purple bottles and pour them in from the nozzle, what I canít get out and in I just end up consolidating into one bottle at the end.
sdg3205 is offline
post #13 of 15 Old 02-25-2020, 11:32 PM
rep-tile
Cash 4 clunkers survivor
rep-tile's Avatar
I've always used a qt bottle that I squeeze and refill with a gallon size container since it's cheaper. All those pumps I've tried ended up in the trash in the first 5 mins. Usually get M1 brand for oil.
04 WJ 4.0 - Avital 4103, DB-ALL
91 XJ 4.0 - Avital 4103, Stage-2 aFe intake system, BBK high flow Throttle Body, 703s injectors, Jones Exhaust A3518M-5
rep-tile is offline
post #14 of 15 Old 02-26-2020, 12:18 AM
Mattimus_LV
Mattimus_LV's Avatar
I use this for the gallon jug of Redline: https://www.amazon.com/Slippery-Pete.../dp/B07DTS8N7P
2004 WJ Overland
Mattimus_LV is offline
post #15 of 15 Old 02-26-2020, 06:55 AM
leadsled jeep
leadsled jeep's Avatar
I use a small section of hose 3-4” long that fits right into a funnel. Then I cut the funnel down so I doesn’t hold much but gives me the ability to pour it in.
Easy
'02 4.7HO ~222k ml. 2.5" BDS Springs, All new control arms and Addco Sways. 245-70-17.
leadsled jeep is offline
