Extreme simultaneous power failure - JeepForum.com
 3Likes
  • 1 Post By GmanWJ
  • 1 Post By juan_carlos__007
  • 1 Post By Sprung99GC
post #1 of 8 Old 08-12-2020, 01:33 PM Thread Starter
Kbrow
1999 WJ 4.0 six cyl. On attempting start, normal dash lights went out, no response to any key position, no crank, no power to electric windows, etc, and all gauges repeatedly recycle across full meter range. Crazy gauge action continues with key off and removed. Battery is strong, 12.9v. Power fuses are good. Is this definitely a Body Control Module BCM issue? Would really appreciate expertise with these symptoms before chasing after the BCM.
Kbrow is offline
post #2 of 8 Old 08-12-2020, 01:46 PM
GmanWJ
GmanWJ's Avatar
My guess: bad grounds. Check the battery-to-engine ground on the side of the block, check the battery-to-fender ground next to the PDC (front of the engine bay). Check battery terminals and CABLES. They should all be free of grease, oil, and corrosion; clean them if you can, replace if needed. Take a look at this thread for more info: https://www.jeepforum.com/forum/f310...-info-4192594/
juan_carlos__007 likes this.
ok mostly just repairs, but we are closing in on a lift
GmanWJ is offline
post #3 of 8 Old 08-12-2020, 02:12 PM
juan_carlos__007
I also think is some loose battery terminals, starter, wire etc. Check that you have good connections.
Sent from my NX629J using Tapatalk
Kbrow likes this.
juan_carlos__007 is offline
post #4 of 8 Old 08-12-2020, 03:41 PM Thread Starter
Kbrow
Thanks for the grounding info, GManWJ. I will focus on main power grounds and Body Control Module grounds as that unit is implicated in all the accessories that are not working. Strange thing is a rapid clicking noise in the area of the BDM when ignition switch is off, also faint glow of side marker lights--with light switch off and ignition off....
Kbrow is offline
post #5 of 8 Old 08-12-2020, 08:39 PM
Bigrigr
Bigrigr's Avatar
X2 Gman, sounds like dirty/loose connections somewhere. Battery post are the most common. Make sure there is NO white corrosion on any of the cables, and double check that it hasn't snuck up under the insulation just beyond the battery connections. If that doesnt get it, follow those grounds....The funky clicking and intermittent gauge operation are a tell tale for bad connections.
'00LMTD-4.7l,242hd,D30,D44A,3.73's,True-trac front,Spartan rear,4" short arm lift,JK'sW/32's
Bigrigr is offline
post #6 of 8 Old 08-13-2020, 08:28 PM
Sprung99GC
Sprung99GC's Avatar
Hit the starter with a hammer while you have someone crank it. I have had many starters hang up over the years.
Sprung99GC is offline
post #7 of 8 Old 08-13-2020, 09:20 PM
2oldjeeps
starters have brittle permanent magnets easily cracked by hitting,then they are junk.
corrosion on copper has no effect on resistance unless wire size is reduced, rarely.
just do soda to feel good.
batt terminals must be clean. i put a big washer on both sides to get a tight fit.
ive rarely had a bad ground if the bolt/nut is tight.
99wj,143,000 miles
00xj,177,000 miles
10hummer3,74,000 miles
98xj,130,000 miles
2oldjeeps is online now
post #8 of 8 Old 08-14-2020, 08:41 AM
Sprung99GC
Sprung99GC's Avatar
Sprung99GC
Well it's worked for me in the past. I replaced the starter so it didn't matter much. All it took was a little tap.
GmanWJ likes this.
