Exhaust Moving And Banging. - Page 3 - JeepForum.com
post #31 of 34 Old 08-26-2015, 09:54 PM Thread Starter
mr312712
mr312712's Avatar
2008 WK
Originally Posted by Jeeples View Post
Try a light coating of WD40 to help pop it back in.
Otherwise you'll need to remove the bracket and use a vice or small press to reinstall it.
The bolts should be a 15 or 16MM IIRC, there's very few standard sized fittings on WJ'S, with the exception of a couple of drive train related fasteners everything is metric from the factory.
I will try again tomorrow, but the bracket bolts are rusted on and I don't have an Impact. But I will soak them In WD-40 tomorow.
It doesn't matter If the guy next to you doesn't know your racing winning Is winning.
Castrol Edge 10W30 Full Synthetic
04 WJ Overland Inferno Red 4.7 MAGNUM V8 HIGH OUTPUT
mr312712 is offline
post #32 of 34 Old 08-27-2015, 07:00 AM
MadderThanMax
You haven't got PB Blaster over there have you - would work better than WD40.. believe me when I say this a can of Coke Cola works better, the fizz breaks through all the rust.
MadderThanMax is offline
post #33 of 34 Old 08-27-2015, 07:06 AM
HarryH3
The exhaust hanger is screwed up because your engine mounts are allowing too much movement. Replace the mounts, reassemble the hanger and then all should be well.
HarryH3 is offline
post #34 of 34 Old 08-27-2015, 08:45 AM Thread Starter
mr312712
mr312712's Avatar
2008 WK
Got some of this freeze off rust and bolts spray, so hopefully this will work.
mr312712 is offline
exhaust , exhaust hanger , exhaust system
