Evap Issues - JeepForum.com
post #1 of 3 Old 10-18-2021, 09:03 PM Thread Starter
2004WJlover
Evap Issues
Hello All, Now Im working on my 2003 WJ its the 4.0L. I keep getting the CEL and codes are for EVAP Small leak and EVAP Large leak. The location on the rear fender and the system as a hole are a joke. Is there a way to trick the computer by jump wiring either the underhood 2 pin harness or the back connector. I hate having the CEL on for such a petty reason. Took the stuff down behind rear tire and cant find a leak, also replaced the gas cap.
I just want to cap the 2 vacuum ports on manifold and unplug controls but how do I jet rid of the CEL.
2004WJlover is offline
post #2 of 3 Old 10-19-2021, 06:24 AM
leadsled jeep
leadsled jeep's Avatar
Working on it isn’t horrible. Taking rear bumper cover off is super easy. I replaced some old rubber hoses and a check valve of some sort and made my CELs go away.
For a WEAK and IGNORANT sheople, SERF-dom is a Reward, not a Curse. W1CCW
leadsled jeep is offline
post #3 of 3 Old 10-19-2021, 07:25 PM
Mattyjm
Mattyjm's Avatar
If you like to "top-off" your gas tank, you'll have this problem sometimes. I just let the pump click off when filling up and return the gas nozzle to the pump. It avoids EVAP issues when the stupid thing can't breathe properly.
2004 Special Edition WJ. LOADED!
Mattyjm is offline
