Engine temp? - JeepForum.com
post #1 of 4 Old 03-31-2012, 04:11 AM Thread Starter
CHEROKEE8
CHEROKEE8's Avatar
Engine temp?
Hey guys my wj(4.7) has run around 210 since i got it a year ago. The other day it jumped way up(245) while running around town (a lot of red lights, up & down hills) so i checked the fan clutch & it was bad. So i replaced it. Now its running 220/230 around town or idling for a while. Is this the temps everyone else runs or what else could it be? Electric fan works fine as well.
CHEROKEE8 is offline
post #2 of 4 Old 03-31-2012, 07:49 AM
HVACNY
HVACNY's Avatar
2013 WK
How did you check the fan clutch?
When your temps gets to 220 and you put your heat on hot and high,does the temp drop down?If so its your radiator.
Do not drive with high temps,your engine will fry.
2000 Jeep Grand Cherokee 4.7 V8
2013 Jeep Grand Cherokee Overland 5.7 Hemi
HVACNY is offline
post #3 of 4 Old 03-31-2012, 08:08 AM Thread Starter
CHEROKEE8
CHEROKEE8's Avatar
To check my fan clutch i just let warm up, then cut it off & check to see how hard it was to turn. It was completly free. the new one spins twice as fast also. Ill try the heat thing today after i get my lift on. Thanks
PIN IT TO WIN IT !
post #4 of 4 Old 04-01-2012, 03:54 PM
Double E
Double E's Avatar
You may also want to think about a radiator swap. It's probably due. Check the rad cap too or just get a new one.
"We have it totally under control. Itís one person coming in from China. We have it under control. Itís going to be just fine." ~D. Trump, Jan 22, 2020.
Double E is offline
Cool engine/temp gauge hot sajohnson05 WJ Grand Cherokee Forum 12 02-15-2016 03:18 PM
WJ Engine Temp gauge readout derekmines WJ Grand Cherokee Forum 6 01-31-2012 10:05 PM
Engine temp rising JeepGuy813 WJ Grand Cherokee Forum 4 10-09-2011 04:43 PM
Engine Temp JeepGuy813 WJ Grand Cherokee Forum 3 06-23-2011 02:58 PM
Getting a bad engine temp reading should I change thermostat? Wil1013 WJ Grand Cherokee Forum 1 07-27-2010 08:38 PM
