Engine swap 02 4.7 grand non ho into 04 ho overland - JeepForum.com
post #1 of 15 Old 02-12-2020, 02:26 PM Thread Starter
Livewire9
Livewire9's Avatar
Can I just swap them out with out changing the ecm??
Livewire9 is offline
post #2 of 15 Old 02-12-2020, 03:46 PM
smokeyyank
So you want to swap a non HO into a HO?
Based on this I'm going to say not because the PCM was programmed differently along with a multitude of other things.
http://www.wjjeeps.com/ho_engine.htm
04 WJ, 4.7HO
3" IRO lift, fastman TB, 32s, lunchbox rear 242HD, 3" exhaust
smokeyyank is offline
post #3 of 15 Old 02-12-2020, 10:47 PM
Bigrigr
Bigrigr's Avatar
Also, the tone ring on the crankshaft for the crank position sensor is different in 03-04. So 99-02 engines wont swap into 03-04 without major bottom end changes.
'00LMTD-4.7l,242hd,D30,D44A,3.73's,True-trac front,Spartan rear,4" short arm lift,JK'sW/32's
Bigrigr is offline
post #4 of 15 Old 02-13-2020, 10:54 AM Thread Starter
Livewire9
Livewire9's Avatar
Hello again I've been researching the compattibilty & gets that the ecm are different 3 plugs on the 16 tone & 4 on the 32 both my rigs have the 3 plug ecm & a build date of 01& 03
post #5 of 15 Old 02-14-2020, 12:11 AM
Bigrigr
Bigrigr's Avatar
Hmmm, sounds like it should work then...
Bigrigr is offline
post #6 of 15 Old 02-23-2020, 01:20 PM
ParkerStovall42
Rotating assembly on the HO is wildly stronger than the standard 4.7 since the HO uses forged components. If your HO ate it and you have a standard engine laying around or that you can pull for cheap and just want to slap it in to get it running again, yeah it'll work and run fine. You'll throw a code for knock sensors since the standard 4.7 doesn't use them. If you have a vin which begins with J rather than N you shouldn't have to mess around with the tone wheels and reluctor ring either.
ParkerStovall42 is offline
post #7 of 15 Old 02-23-2020, 11:05 PM Thread Starter
Livewire9
Livewire9's Avatar
My 02 4.7 has the nubs 4 knock sensors I'm just going to install them right where they came from the 04 ho engine. no tone ring differences between the two 3 pin/ connections pcm's only on the 4 pin late 04/5 & on..even on vin j vs n...research research and more research= the right / correct answers. & eye strain..thank you for your insight into the delima and happy trails..
post #8 of 15 Old 02-24-2020, 01:31 AM
sdg3205
sdg3205's Avatar
Are you sure you're not looking at the lift dowel holes? Can you post a pic? Im curious how your non-HO has knock sensor holes
sdg3205 is offline
post #9 of 15 Old 02-24-2020, 08:41 AM Thread Starter
Livewire9
Livewire9's Avatar
Sure soon as I get out there to swap intakes and install sensors . I have read that the mfg had allready modified the blocks in 00 in preparation for the Ho.? Makes seance to me. Stand by.
post #10 of 15 Old 02-24-2020, 06:31 PM
Bigrigr
Bigrigr's Avatar
Quite intriguing...
Bigrigr is offline
post #11 of 15 Old 02-24-2020, 10:14 PM Thread Starter
Livewire9
Livewire9's Avatar
Ho on right.. non ..left knock nubs just need tapping. done& done. Going back in Tomarrow dispite 30' weather & snow.sadly so much bad/miss info out there & a lot of good as well.Safe travels.
IMG_20200224_162739_01_1582607208824.jpg   20200224_162956_1582607387174.jpg   20200224_162948_1582607551635.jpg
post #12 of 15 Old 02-26-2020, 10:17 AM
Bigrigr
Bigrigr's Avatar
Nice...
Bigrigr is offline
post #13 of 15 Old 02-26-2020, 10:49 AM Thread Starter
Livewire9
Livewire9's Avatar
Now the fun begins.. I still have to believe that it will R in better with a more advanced pcm regardless of the compression differences between the two . it will breath better the ho's y pipe & exhost is less restrictive & I dumped/ removed the muffler as well .
post #14 of 15 Old 02-26-2020, 05:33 PM
Bigrigr
Bigrigr's Avatar
Oh you have improved upon the standard HO no doubt. It wont be quite as good as the original HO, but maybe you wont even notice....
And driving down the street is better than sitting on blocks in your driveway, no matter what V8 you have.
Bigrigr is offline
post #15 of 15 Old 02-27-2020, 09:15 AM Thread Starter
Livewire9
Livewire9's Avatar
Amen brother
