Electrical Gremlin? - JeepForum.com
post #1 of 2 Old 09-30-2019, 10:13 AM Thread Starter
Ninjachef93
Electrical Gremlin?
So I have a 2000 wj, and I've been experiencing problems with the odometer cutting in and out, which now seems to be all non auxiliary power. Idles wierd, shudders while driving when the odo cuts out and resumes when it comes back on. I've replaced the alternator, battery, stripped back battery wires and replaced terminals, and even replaced the tensioner. There are no codes at all on my obd2 nor on the odo with the key dance. I'm in over my depth and if someone can just say "it's probably this", that'd save my life. I've got an important job lined up and this lovely pile is going to ruin it for me.
Ninjachef93 is offline
post #2 of 2 Old 10-01-2019, 12:31 PM
Mattyjm
Mattyjm's Avatar
Sometimes the Crank Position sensor can go bad and not set a code. Also, if you're not getting any communication from your PCM, that's a bad sign.
2004 Special Edition WJ. LOADED!
2004 Rocky Mountain Edition. Froggy Bandit. Wife's Daily Driver. PRISTINE! Stock height and may stay that way.....
Mattyjm is offline
