Driveline vibes/rumble on acceleration - JeepForum.com
post #1 of 11 Old 09-05-2019, 12:06 AM Thread Starter
sdg3205
sdg3205's Avatar
Iím running 2Ē spacers on upcountry springs. I recently added new coil isolators which probably added 1/2Ē of lift. At this point everything was fine. But, the rear axle was starting to tuck in close to the front of the rear wheel wells so I installed IRO rear lower control arms to push the axle back to centre. I also added a BDS upper arm spacer to level out the upper control arm.
Now, under harder acceleration I get a rumble, which must be vibrations. Itís smooth at any speed and under less aggressive acceleration and also smooth and quiet on deceleration.
I take it the lower rear arms has thrown off the pinion angle? The DS has pulled another 1/2Ē out of the transfer case slip yoke, so perhaps the longer driveline has a balance issue?
Anyway, any input would be great.
sdg3205 is offline
post #2 of 11 Old 09-05-2019, 06:18 AM
Oktavius
Definitely need to check the pinion angle. Upper arm spacers also affect the pinion angle as the upper arm is a fixed length but in a different position in its rotation. So combination of the adjustable lower arms and the upper arm spacer definitely changed your pinion angle.
Oktavius is offline
post #3 of 11 Old 09-05-2019, 12:20 PM Thread Starter
sdg3205
sdg3205's Avatar
The gap between the tire and fender in the front is 6". The gap in the rear is 6.5". I'm going to remove the lower spring isolator which should bring the gap in the rear down 1/2". I should then be able to tweak the lower arms pull the axle forward slightly. This may be all it takes. 1/2" goes a long way (thats what she said!).
sdg3205 is offline
post #4 of 11 Old 09-05-2019, 04:33 PM
Oktavius
Still need to measure the driveshaft angle when you are done.
Also, have to plan for the arc motion of the axle. If you center the axle in the wheel well at right height, the axle shifts rearward as suspension travels upwards. Could contact the rear of the fender lip when at compression.
Oktavius is offline
post #5 of 11 Old 09-05-2019, 04:38 PM Thread Starter
sdg3205
sdg3205's Avatar
For sure. I have a gravity angle finder. Just need to find some time.
sdg3205 is offline
post #6 of 11 Old 09-05-2019, 11:59 PM Thread Starter
sdg3205
sdg3205's Avatar
Pinion angle looks to be about 10 degrees, with the DS at 14 degrees and the pinion at 4 degrees.
EDIT - I don't know why it's rotating two of my pics 90 degrees to the left, but just imagine the 2 pics below are rotated to the right.
sdg3205 is offline
post #7 of 11 Old 09-06-2019, 07:57 AM
Oktavius
Not sure of where the 4 degrees is being measured off of.
That 12 degrees is just your driveshaft angle relative to the ground. Pinion angle is the difference between your driveshaft angle and the mating surface of the pinion yoke.
https://www.wolferacecraft.com/pinionangle.aspx
Oktavius is offline
post #8 of 11 Old 09-06-2019, 09:20 AM Thread Starter
sdg3205
sdg3205's Avatar
Thatís correct
4 degrees is the pinion itself.
If it makes more sense to you, if the numbers are inverted 90 degrees, the DS is 77 degrees and the pinion is 87 degrees, still 10 degrees.
sdg3205 is offline
post #9 of 11 Old 09-06-2019, 10:06 AM
HarryH3
What's the angle at the t-case end of the driveshaft? U-joints travel in an elliptical pattern. If the angle at both ends aren't exactly opposite of each other (i.e. +10 at one end and -10 at the other, then you'll have some driveshaft vibration as the joints fight each other). I would try lengthening the lower arms a bit, to rotate the pinion down a few degrees. The closer that you get to matching the angle at the other end, the smoother it will operate.
Here's a vid that shows the effect in action:
HarryH3 is offline
post #10 of 11 Old 09-06-2019, 10:46 AM
Oktavius
Thatís correct
Ah, you don't have all of the measurements to determine where your pinion angle needs to be as HarryH3 is pointing out. For conventional, 2 joint driveshafts, you need three measurements. Transfer case output, driveshaft, and pinion yoke. Couldn't if your 4 degrees was on the transfer case or pinion.
If you have a double cardan driveshaft, you would only need the driveshaft and pinion measurements but in that case would aim for zero degree difference.
When I setup my rear driveshafts, I aim to have the pinion angle 1-2 degrees down in relation to the transfer case output. So in HarryH3's example, if the transfer case output angle is +10 degrees, then the pinion angle is -11 degrees. This is to count for axle twist under acceleration.
Oktavius is offline
post #11 of 11 Old 09-06-2019, 10:49 AM Thread Starter
sdg3205
sdg3205's Avatar
Gotcha! i'll check that out and report back. thanks guys!
sdg3205 is offline
