Dead battery after = no idle? - JeepForum.com
post #1 of 9 Old 02-11-2019, 04:57 PM Thread Starter
xcaliber81
xcaliber81's Avatar
Battery kind of died after not being ran in 4 or 5 days in -20 to -40 temps.
I put a new battery in and it refused to idle for some time not so sure why that happened.
My guess in the battery was just too old and over the past few cold starts ive noticed harder starts I was wondering if my block heater wasnt working or the battery was just weak after the years.
Well It did idle after a while of me revving to 1000 rpm for a few mins.
Is this normal wj operation after having a dead battery?
xcaliber81 is offline
post #2 of 9 Old 02-11-2019, 05:15 PM
Robinton
Most computer controlled vehicles can have driveability issues after a battery change until the computer relearns it's parameters.
Robinton is offline
post #3 of 9 Old 02-11-2019, 07:24 PM Thread Starter
xcaliber81
xcaliber81's Avatar
I tested my block heater and at the end of the plug and its not working (I knew it), is this a chore to replace?
post #4 of 9 Old 02-11-2019, 09:22 PM
2oldjeeps
2oldjeeps's Avatar
i have a 4.0 xj where i unhook batt for a few days. it does this when restarted.
99wj, 150,000 miles
00xj ,189,000 miles
10hummer3,76,000 miles
98xj, 133,000 miles
2oldjeeps is offline
post #5 of 9 Old 02-12-2019, 12:22 PM
frankjc
WJs don't like it when the battery gets run down. Mine did all kinds of strange things after it was parked for a while last summer.
frankjc is offline
post #6 of 9 Old 02-12-2019, 04:45 PM
Dan_in_MN
4.0 or 4.7?
2000 WJ Grand Cherokee Black 236,000+ miles
Needs: Left rear wheel bearing. Front right CV joint.
Dan_in_MN is offline
post #7 of 9 Old 02-13-2019, 08:43 AM Thread Starter
xcaliber81
xcaliber81's Avatar
Originally Posted by Dan_in_MN View Post
4.0 or 4.7?
4.7 it's also listed in my specs.
post #8 of 9 Old 06-01-2020, 02:26 PM
Veronica01
[QUOTE=xcaliber81;40517733]Battery kind of died after not being ran in 4 or 5 days in -20 to -40 temps.
Seriously I just went through this. I charged battery and then it wouldn’t idle. I gave it gas and eventually started- but had it to do it each time I cranked it- i had tricked memory into thinking it needed those additional rpm to run- I unhooked cables let it sit 30 minutes.. hooked it back up. Turned ignition to start lights on dash - not fully cranked- waited 10 seconds- cranked and it reset memory! Runs great now.
Veronica01 is offline
post #9 of 9 Old 06-01-2020, 11:28 PM Thread Starter
xcaliber81
xcaliber81's Avatar
My block heater was the culprit it gave up the fight right around when I made this post. I still haven't fixed it lol instead I put an oil pan heater and that oil pan heater all by itself made it through a -45 to -50 celcius cold snap for 4 days!
12 Things You Can Do When Your ZJ Stalls ZeeJay1997 ZJ Grand Cherokee Forum 451 07-29-2021 07:16 PM
ZJ wouldn't start, problem was WEAK battery (PCM lost settings for fuel/air mixture) chimpanzee ZJ Grand Cherokee Forum 5 11-19-2018 03:10 PM
Dead short on battery positive Beechjeep WK Grand Cherokee & XK Commander Forum 2 06-20-2018 09:40 AM
New Badger build thread azzkicker WK Grand Cherokee & XK Commander Forum 10 06-18-2018 08:55 AM
How much driving to recharge a stone dead battery? Esmerda1125 ZJ Grand Cherokee Forum 7 03-15-2018 03:16 PM
