Dead Battery - JeepForum.com
post #1 of 6 Old 04-04-2020, 10:36 PM Thread Starter
debbiel
Dead Battery
99 Jeep Grand Cherokee limited - new battery, new Altanator. If I don't start the car for 1 day I get. Dead battery no clicks. I see a red light on on the set panel on the driver door. Any ideas?
debbiel is offline
post #2 of 6 Old 04-05-2020, 07:40 AM
axlaxl
First things first, if you have a multi meter, or can borrow one from a place like autozone, test the battery and alternator.
https://haynes.com/en-us/tips-tutori...ery-multimeter
If that eliminates the battery and alternator you may have a different issue. I've drained a battery in my car just accidentally leaving an overhead light on overnight.
axlaxl is online now
post #3 of 6 Old 04-05-2020, 07:51 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Originally Posted by debbiel View Post
99 Jeep Grand Cherokee limited - new battery, new Alternator. If I don't start the car for 1 day I get. Dead battery no clicks. I see a red light on on the set panel on the driver door. Any ideas?
New does mean functioning properly, the first thing to do is have the alternator and battery Load Tested at an auto parts store or repair shop. The starting and charging wire circuits should be inspected and tested for loose, damaged, or corroded connections and wires.
Basic troubleshooting suggests that there is a parasitic voltage drain due to a switch malfunction, electrical circuit malfunction, or a short circuit from damaged wiring.
“When the people find that they can vote themselves money, that will herald the end of the Republic.”
- Benjamin Franklin
CJ7-Tim is offline
post #4 of 6 Old 04-05-2020, 02:58 PM
2oldjeeps
after driving ,shut off and read batt volts. should be 12 to13.
restart,should be 14 +. if so its charging.
pull headlites while reading. volts dip and come back up. its charging..
shut off, unhook one batt cable. read leakage current with doors closed, all lights off.
should be less than 1oo ma,1/10 amp or lower. if it is, batt is bad,wont hold charge.
if its higher you have leakage and you pull fuses till it goes away.
i havnt read mine lately but i think its less than 20 ma. ill check soon or someone jump in...
my hummer is 110 ma but jeep is lower...
99wj,143,000 miles
00xj,177,000 miles
10hummer3,74,000 miles
98xj,130,000 miles
2oldjeeps is offline
post #5 of 6 Old 04-05-2020, 09:33 PM
chris87xj
JF Admin
chris87xj's Avatar
1987 XJ Cherokee
Moved to WJ land.
***Chris***
chris87xj is offline
post #6 of 6 Old 04-06-2020, 06:08 AM
keith20mm
Inspect power cable in door hinge jamb, open rubber boot, repair all broken wires.
The SET button is hint of a broken wire or wires, from cable flexing.
2000 WJ 4.7 2WD 300000+ mi, 2nd engine/trans
2000 WJ 4.7 4WD 258777 mi, 2nd engine
keith20mm is offline
