Dana 44 vs Dana 44a Pinion Seal - Are they the same? - JeepForum.com
post #1 of 2 Old 02-18-2020, 08:27 PM Thread Starter
caliskier
I am nervous about ripping into my 1999 Grand Cherokee Rear differential pinion seal. All I can find are seals for the Dana 44 not the Dana 44a, are they the same seal?
Thanks
caliskier is offline
post #2 of 2 Old 02-18-2020, 10:18 PM
Bigrigr
Bigrigr's Avatar
No, they are not the same seal. The 44A has a larger pinion gear/bearing/seal than the regular 44. If you have to, get the number off the old one, to match it up. I havent had any trouble getting seals for mine.
Guess you must've found your leak?
'00LMTD-4.7l,242hd,D30,D44A,3.73's,True-trac front,Spartan rear,4" short arm lift,JK'sW/32's
Bigrigr is offline
