Dana 30 or 44 or both? - JeepForum.com
post #1 of 26 Old 06-22-2012, 06:45 PM Thread Starter
newrubicon
Can someone help me in figuring out which axles I have in my Grand Cherokee. It's a 2002 Limited,NV247 T-Case, 4.7 V8. From what I read it should have the vari-lock Dana 30 in the front, ( is that right?) but it's the rears I'm not sure about. Would it be the 44 or was that optional ? Thanks.
newrubicon is offline
post #2 of 26 Old 06-22-2012, 06:48 PM
BLACK04WJ
BLACK04WJ's Avatar
06 LJ Rubi / 97 TJ / 04 WJ
Oct '12 GCOTM
https://www.jeepforum.com/forum/f22/unlimited-lj-2212193/
BLACK04WJ is offline
post #3 of 26 Old 06-22-2012, 07:16 PM
billzcat1
Chicken in a Turkey Suit
2003 WJ
Note that you'll only have the VariLok differentials if you have the QuadraDrive 4WD system.
~Richard
billzcat1 is offline
post #4 of 26 Old 06-22-2012, 07:26 PM
BLACK04WJ
BLACK04WJ's Avatar
Oct '12 GCOTM
post #5 of 26 Old 06-22-2012, 07:29 PM
narnwv
narnwv's Avatar
Originally Posted by BLACK04WJ View Post
the OP said he has the NV247..
Sent from my WJ using JeepPower
which was used in both Quadra-Trac (no vari-locks) and Quadra-Drive (vari-locks in the axles)
Regardless, with the v8, you have a Dana 30 in the front and the Dana 44a in the rear. It's aluminum, and is different than the iron 44 (completely different if you're looking for parts)
~Aaron
narnwv is offline
post #6 of 26 Old 06-22-2012, 07:30 PM
pinky2252s
pinky2252s's Avatar
It is stamped on the diff it self, if you want a fool proof method of knowing. At least mine does. It says "DANA 30" in a diamond...
Is it broken?
Colorado Jeep Club Member #2252
2001 Laredo, 2004 Special Edition
pinky2252s is offline
post #7 of 26 Old 06-22-2012, 07:30 PM
BLACK04WJ
BLACK04WJ's Avatar
I did not know that
thanks for the information
Oct '12 GCOTM
post #8 of 26 Old 06-22-2012, 07:41 PM Thread Starter
newrubicon
Thanks. But I'm confused with the drive systems and vari-locks, It's a Quadra-trac II so does it have vari-lock. According to an article I read the vari-lock came on starting in 02. Or was it an option?
post #9 of 26 Old 06-22-2012, 07:50 PM
narnwv
narnwv's Avatar
Vari-Lock axles were only part of Quadra-Drive. If you have Quadra-Trac II, then you do NOT have the Vari-Lock limited slip axles, sorry.
Vari-Lock was available from 1999, the first year of the WJ.
~Aaron
narnwv is offline
post #10 of 26 Old 06-22-2012, 07:51 PM
billzcat1
2003 WJ
Special Order Option to add a rear LSD to the QuadraTrac II system. Not standard by any means. It is most likely that you have open differentials if you have Quadra-Trac II.
Read up here: https://www.jeepforum.com/forum/f310/.../#post12259930
And here: http://wjjeeps.com/tcases.htm
~Richard
post #11 of 26 Old 06-22-2012, 09:05 PM
MuddyWJ
front Dana 30 vari-lock
rear Dana 44a vari-lock
if you had the I6 instead of the V8 you would have a rear Dana 35
I have the I6 and have a 44a rear.
MuddyWJ is offline
post #12 of 26 Old 06-22-2012, 09:07 PM
narnwv
narnwv's Avatar
Vari-Lock? All Quadra-Drive equipped WJs have D44a rear axles
~Aaron
narnwv is offline
post #13 of 26 Old 06-23-2012, 09:27 AM
MuddyWJ
Yes vari-lok front and rear. Black made a statement than I6 come with the 35.
MuddyWJ is offline
post #14 of 26 Old 06-23-2012, 10:18 AM
narnwv
narnwv's Avatar
Unless equipped with Quadra-Drive. ALL QD rear axles are D44a.
Is your rear diff oval? Or are there some straight edges to it?
~Aaron
narnwv is offline
post #15 of 26 Old 06-23-2012, 11:03 AM
MuddyWJ
My bad I do have quadradrive. Mis communication
MuddyWJ is offline
Dana 44 vs Dana 44HD vs Ford 8.8 pic BradMB2004 WJ Grand Cherokee Forum 29 07-19-2018 09:41 AM
WJ Dana 30 vs JK Dana 30.. axle tube diameters and Inner C sizes??? LSRGreg WJ Grand Cherokee Forum 35 08-13-2014 11:15 AM
Dana 30 spider gears vs dana 35? terrgill WJ Grand Cherokee Forum 4 05-03-2011 05:48 PM
Dana 30/Dana 35 differential carrier? terrgill WJ Grand Cherokee Forum 1 04-19-2011 03:50 AM
What is everyones preferred fluid for 242 TC, Dana 30 and Dana 35? FleshEater WJ Grand Cherokee Forum 8 02-06-2011 07:48 PM
