Could use some help - JeepForum.com
 2Likes
  • 2 Post By CarlJH
post #1 of 6 Old 06-09-2019, 07:58 PM Thread Starter
srdris
srdris's Avatar
Wj Could use some help
Hey everyone, new to the forum here and thought i would get an opinion from other wj owners for an issue im having. So im more new to the wj, have come from owning an zj before and got a deal on a 02 limited 4.7 with a blown motor but rebuilt trans. found another good deal for the 4.7 HO complete swap from the same year and did a quick tune up including timing chains and tensioners, spark plugs, new front and rear main seals, water pump and coolant hoses, pretty much the whole nine yards for the motor so i could get some camping and hiking done in it and not really worry too much on having that 4.7 let me down. but where im from the car has to pass an emissions test to get it road legal, but i have an engine code P1492 that comes up. i know its for the battery temp sensor, and ive replaced the sensor 3 times and have cleared the code with a scan tool everytime but still comes back. ive attached pices of the code itself because im unsure of what the second part of the code means. and ive tried google and just searching for an answer online to no luck but maybe someone can point me in the right direction.
srdris is offline
post #2 of 6 Old 06-09-2019, 08:32 PM
CarlJH
2003 WJ
usually you have current and stored trouble codes, maybe your code reader isn't able to clear the stored codes?
also if you have tried 3 different temp sensors maybe need to check the wiring harness as well for any breaks damage.
Ravenbar and GmanWJ like this.
CarlJH is offline
post #3 of 6 Old 06-11-2019, 10:22 AM
GmanWJ
GmanWJ's Avatar
Concur with CarlJH. You have replaced the sensor but that did not fix it. You need to check those wires for continuity to make sure the signal that the sensor is generating is reaching its destination. Check the grounds too, if they get crudded up they might lose connection.
ok mostly just repairs, but we are closing in on a lift
GmanWJ is offline
post #4 of 6 Old 06-11-2019, 10:58 AM
Robinton
Robinton's Avatar
2003 WJ
Isn't the ambient temp sensor the one the evic uses to tell the outside temperature?
I don't think it has anything to do with the battery temp sensor.
You're never lost when you don't care where you're going.
Robinton is offline
post #5 of 6 Old 06-11-2019, 11:51 AM
jtec
2014 JK Wrangler
details- never easy....
jtec is offline
post #6 of 6 Old 06-14-2019, 05:06 PM Thread Starter
srdris
srdris's Avatar
so before posting i found a link that said how to measure the sensor and from there ended up changing the sensor because it wasnt in the acceptable ohm range. it also said that the voltage going to the sensor should be about 5v, which is what i was reading on my multimeter. from the website "Take the sensor to a location where the temperature is 75 - 80* and measure the resistance. A good sensor will have a resistance of 9,000 - 11,000 ohms.
If the resistance is not correct, replace the sensor. Because of the code and MIL, you probably should replace it anyway. An extra check before replacing it would be to check the voltage applied to the sensor. Connect a voltmeter across the terminals of the harness connector and turn the ignition key to the ON position. The voltage should be about 5 V. If that's not correct, then there is a problem in the connector or, worse still, the PCM.
The BTS is used to determine the battery temperature
and control battery charging rate."
that being said i checked some ground wires and will probably be checking for continuity here shortly.
srdris is offline
