Coolant disappearing with no visible leak - Page 2 - JeepForum.com
 5Likes
post #16 of 27 Old 09-08-2021, 04:41 AM
jpcallan
Time for coolant leak tracing dye
Add coolant dye to the radiator and wait a week. The leak location will be marked with a bright green stain under UV or violet light. You may need to borrow or rent a UV inspection light. See:
https://tracerproducts.com/leakfinde...s/coolant-dye/
LF3001CS is the single dose size available on Amazon for $7.
Fluorescent dyes are often available in different colors to differentiate the medium being traced. Yellow for refrigerant, blue for motor oil or transmission fluid, etc.
A friend had a beloved BMW 733i he bought new that picked up the habit of constantly losing coolant. The BMW dealer sold him a new radiator, hoses, service after service, ultimately amounting to big $$$, but the coolant loss continued. He finally trusted me to try to find the leak with dye. I added yellow Tracerline dye. After a week of driving, he brought the car over after dark for an inspection. There were two leaks - the top of the white plastic radiator expansion tank had subtle fatigue cracks with a big fried egg yellow dye stain on top; leak number two was a white plastic heater valve with tiny cracks and a small yellow dye stain. I changed the expansion tank, but was not equipped to remove the dash to change the heater valve, but the bottom line is the leaking stopped.
These leaks can be hard to isolate because often water vapor is leaking, not liquid water. If the leak is in the heater core, you may see green dye stains in the condensate dripping from the air conditioning evaporator drain.
Be sure to use distilled water as make-up water and not tap water to avoid plugging up your radiator with mineral deposits from hard water.
jtpeters likes this.
jpcallan is offline
post #17 of 27 Old 09-08-2021, 10:29 AM
BlueOffroader
BlueOffroader's Avatar
When I was trying to figure out where my coolant went. It ended up in passenger side floor carpet. Whole thing was soaked due to broken heater core.
BlueOffroader is offline
post #18 of 27 Old 09-08-2021, 03:53 PM
CraigMBAx
CraigMBAx's Avatar
Originally Posted by Rylxmp View Post
The mechanic said that he found no other leaks after preforming a pressure test on the cooling system and also no signs of a bad headgasket.
Welp it's going somewhere, and the number of places it can go is limited. If it's not on the ground it's out the exhaust.
Just because he can't find it doesn't mean it's not disappearing.
1999 WJ Limted - Ex Soccer Mom ride turned Rule 25 Compliant Bike Hauler
CraigMBAx is offline
post #19 of 27 Old 09-09-2021, 07:50 AM
snowbuggy
Probably just steaming out of a defective radiator cap.
snowbuggy is online now
post #20 of 27 Old 09-09-2021, 11:17 AM
Delta0
Ditto
Delta0 is offline
post #21 of 27 Old 09-09-2021, 11:37 AM
jpcallan
Heater core leak
The wife's 1996 ZJ suffered the same fate as @BlueOffroader . We took the dash out and replaced the heater core early this spring, 2021.
Our coolant leak symptoms were strange. We had 'waterfall noise' frequently from the heater for years and wet carpet (but no antifreeze) to confuse things (rain leak). The engine, trans, and transfer case were all rebuilt last fall with the body sitting undriven for about 2 months in fairly warm weather. When the cooling system was refilled, the heater core leaked like mad at first, the carpets obviously stained with sweet-tasting antifreeze. A new heater core was quickly purchased, but for no explicable reason, the leaking quickly stopped and the radiator held pressure. We again had 'waterfall noise', and the rain leak into the cabin, but no antifreeze soaked carpet. Somehow the heater core had healed itself.
This past spring of 2021 we bit the bullet, pulled the dash and installed the new heater core purchased the previous fall; rain leaks were caulked. No more 'waterfall noise' nor wet carpet. On inspection of the old heater core, there were multiple blue-green stains where it had been leaking, but after back-flushing the core in the kitchen sink, a ton of blue-green sludge came out.
My theory is the sludge was plugging the holes; the sludge dried out and shrank while the vehicle was under repair, so the core leaked like mad initially, then the sludge re-hydrated and expanded to plug the leaks. After driving, when the engine cooled off, air entered the heater core, causing the 'waterfall noise'. Many Jeep GC owners have reported 'water sound', 'waterfall noise', 'sloshing noise', etc. I suspect these are all heater core leak sufferers with air in the heater core.
jpcallan is offline
post #22 of 27 Old 09-09-2021, 11:50 AM
jpcallan
Leaking radiator cap
Buy a new Stant radiator cap at a NAPA or get a MOPAR part from the dealer, and see if the pressure loss stops. @snowbuggy 's advice may save you a lot of fruitless effort.
I spent my career as a mainframe systems programming consultant. When the computer system would suddenly misbehave, the first question always asked was "What was changed recently?" For you it sounds like the answer to that question is the new radiator cap.
Another question, is the coolant in the expansion tank going up and down, or is it pretty much stuck at one level?
You might also take a peek down the radiator's water neck and look for bits of crud or nicks in the seat where the radiator cap seal rides.
jpcallan is offline
post #23 of 27 Old 09-12-2021, 11:01 AM
Golden-Arm
Golden-Arm's Avatar
it could be paranormal activity in his cooling system.
97Mule, CraigMBAx and WJ60 like this.
Uphill Slow, Downhill Fast, Tonnage First, Safety Last!
Golden-Arm is offline
post #24 of 27 Old 10-14-2021, 01:21 PM
RadarRider
Have you had any luck finding the problem yet?
RadarRider is offline
post #25 of 27 Old Yesterday, 09:51 AM
kwarbington
I was losing about 1 quart coolant per month for three years and it was coming from the thermostat housing. I installed probably 3 or four of the paper gaskets to try and fix it and even replaced the thermostat housing, but made no difference. There was rarely any real sign of moisture anywhere and nothing getting to the ground, but I would see a small buildup of some yellow pasty stuff below the housing on top of the water pump. I never used anything but the paper gaskets because I did not want to have to scrape off the silicone if I had to go in again, but about 3 months ago, I replaced the paper gasket one more time and generously coated both sides of the gasket with the permatex RTV cooling specifically for water cooling systems. Have not added coolant since. Do not know if that info can help you, but good look!
kwarbington is offline
post #26 of 27 Old Today, 10:42 AM
xjpete
xjpete's Avatar
1997 XJ Cherokee
MY 01 WJ was fine then started losing coolant. The hose that attaches to the side near the radiator cap was the issue. I could see where it was wet after driving maybe 6 miles. I put a clamp on it and no more losing coolant. Also my Duralast radiator cap was replaced earlier this year as it didn't seal as it should.
2001 Jeep Grand Cherokee WJ Laredo 4.0 purchased Sept 2014.
xjpete is offline
post #27 of 27 Old Today, 11:10 AM
Delta0
Perhaps everybody already knows this,
Paper gaskets need soaking in water before they are used.
Took me years to find out.
Delta0 is offline
