Cant find DANA 35 rear w/ 30 spline axles - JeepForum.com
post #1 of 5 Old 08-17-2018, 03:28 PM Thread Starter
THawkbh
I'm replacing the bearings on the passenger side rear axle. I accidentally cut into the axle so I need to replace it. Only problem is I can't find one. It has a Dana 35 rear with the 30 spline bolt in axles. I'm only finding the standard 27 spline axles. I did find and buy a 29" 30 spline axle from xdiff, but it was about an inch and a half too short. Does anyone know where I can find the correct 30.5" 30 spline axle for the passenger side rear? I could use a new tone ring too. The old one doesn't want to come off, even with heat. That's also proving hard to find.
Forgive me if this gets talked about a lot. I did a search and wasn't able to find anything.
THawkbh is offline
post #2 of 5 Old 08-18-2018, 06:52 AM
Motorcharge
Motorcharge's Avatar
Currie will respline axles for like $120 or so.
Check your local machine shops as well.
|SOLD|
| June 2015 COTM |
Motorcharge is offline
post #3 of 5 Old 08-18-2018, 07:00 AM
ravenworks
ravenworks's Avatar
Mossler axles
Semper-Fi "81-84"
I.U.O.E. - 18
ravenworks is offline
post #4 of 5 Old 08-18-2018, 09:25 PM
willis36
willis36's Avatar
What wj d35's came with 30 spline shafts? Only d35 30 splines i have seen were super 35 kits for tj's.
willis36 is offline
post #5 of 5 Old 09-04-2018, 10:58 AM Thread Starter
THawkbh
it appears to be an aftermarket kit.
THawkbh is offline
