Can you check if the rear UCA bushings are bad without pulling the arm? - JeepForum.com
post #1 of 17 Old 07-19-2020, 06:26 PM Thread Starter
AVR2
I've checked the ball joint on my rear UCA by using a pry bar to lever between the top of the diff and the tip of the arm - there's no play there. Is there any way to check the condition of the two frame-end bushings without pulling the arm to look?
AVR2 is offline
post #2 of 17 Old 07-19-2020, 08:08 PM
snowbuggy
One of my WJ's has bad upper control arm bushings and it is very obvious by looking at them. They are all twisted out of whack. It probably helps me to have another Jeep with good bushings to compare to.
snowbuggy is offline
post #3 of 17 Old 07-19-2020, 10:09 PM
speednjay
speednjay's Avatar
On my Jeep they still looked good and had some stiffness. I replaced everything anyway and it was night and day compared to the old bushings. If you think they’re soft then change them. It’s not a huge or expensive job
speednjay is offline
post #4 of 17 Old 07-20-2020, 12:44 PM
87_Pioneer
1991 XJ Cherokee
I'd say yes, the other day I had my WJ jacked up with the tires off and jack stands under the rear axle (so just sitting at ride height, no droop); and with a good light I could easily see that the upper A-Arm bushings were starting to crack and tear.
They looked bad enough that I went ahead and bought a new A-Arm w/ bushings (Dorman, $75 shipped @ Amazon) and a new ball joint (Mopar, $50 + shipping @ RockAuto). I hope the Dorman A-arm is OK quality, it had good reviews but their quality is becoming very hit or miss these days. The factory Mopar a-arm is not affordable, and RockAuto had a Moog one for $65, but shipping on it would be $240. Yes two hundred and fourty dollars.
I haven't physically checked the ball joint yet but I've had the A-arm out before and the job is kind of a PITA so to me it's worth it to just replace everything at once. In my case something in my rear suspension is making a thumping sound over bumps so I suspect it's bad anyway....
87_Pioneer is offline
post #5 of 17 Old 07-20-2020, 01:09 PM
MuloChico
2006 WK
Not sure of the Dorman parts, I agree on the hit/miss on quality. I just refreshed all my suspension with parts from Kolak. The upper was a little more expensive than the Dorman parts, but they were Crown Auto brand. Very good quality.
I would highly suggest checking with Kolak before purchase in the future. His shipping costs are good and he gives a decent discount with very good info when it comes to making a decision.
MuloChico is offline
post #6 of 17 Old 07-20-2020, 07:34 PM Thread Starter
AVR2
Interesting - I thought Crown were meant to be very hit-or-miss quality these days? I've read lots of opinions from people who think they're flat-out crap.
AVR2 is offline
post #7 of 17 Old 07-22-2020, 01:50 PM
87_Pioneer
1991 XJ Cherokee
It seems like almost any brand making aftermarket versions of factory replacement parts is hit or miss these days. I've heard the same thing about Crown as well and Omix-Ada too. I've only had personal experience with Dorman and in the past 10 years of using their parts some of their stuff has been great, like O.E. quality or very close, and some has been really cheap junk that I didn't trust enough to use and returned for another brand. Seems like buying parts is basically a gamble.
I just try to use OE parts whenever I can afford to, but even for an 18 year old super common Jeep, plenty of items are stupid expensive from the dealer...
post #8 of 17 Old 07-23-2020, 03:31 AM
Uniblurb
Uniblurb's Avatar
Just as a heads-up Omix-ADA makes nothing of their own. They just relabel other manufacturers parts, jack the price way up, then sell the parts as their own. I've seen them do this with Walker exhaust parts, Valeo radiators, and believe they do the same with Crown parts.
Stay clear of Omix-ADA altogether and I've been ripped off once by them and never again.
2004 4.7L WJ Limited, 96 4.0 ZJ
Uniblurb is offline
post #9 of 17 Old 07-23-2020, 05:59 PM Thread Starter
AVR2
It does seem that many OE parts have leapt in price over the last few years. Maybe it's due to the WJ design being 21 years old now, so stocks of OE parts are being run down and their price has been going up as they become rarer?
I mean, the Mopar rear UCA is now $500 at RockAuto. It never used to be that much, did it?
Apparently the full dealer list price is nearly $900, some Mopar discounters are offering it for $600 and others say it's discontinued.
AVR2 is offline
post #10 of 17 Old 07-24-2020, 06:43 AM
CarlJH
2003 WJ
the Mopar prices went thro the roof when FIAT bought Chrysler and they needed to get as much money back as they could, didn't help with anything to do with the diesel models was Mercedes so FIAT obviously didn't want to be paying them licencing fees to use their parts.
CarlJH is offline
post #11 of 17 Old 07-24-2020, 12:57 PM
Uniblurb
Uniblurb's Avatar
Some good info Carl and makes sense. Plus I was at the Jeep dealer once and ended up in the Fiat showroom waiting for a Jeep part. Those little boxy Fiat cars sure seemed expensive for what you get!
As far as control arms go I've always leaned towards Mopar parts. But you may want to read Gman's long running build thread on here. I remember him buying replacement Mopar control arms and he said they were complete junk while wore out in just a couple months. I don't believe he was talking about the rear upper A-arm but just thought I'd pass this along.
Uniblurb is offline
post #12 of 17 Old 07-24-2020, 05:34 PM
87_Pioneer
1991 XJ Cherokee
I received my Dorman upper A-arm and the bushings are pressed in facing in completely different directions. That's not correct, right? Seems to me like the orientation of the bushings should be symmetrical.
1991 XJ Laredo
1969 Kaiser-Jeep Wagoneer
2002 WJ Limited
post #13 of 17 Old 07-24-2020, 11:09 PM
Golden-Arm
Golden-Arm's Avatar
post a pic or two?
Uphill Slow, Downhill Fast, Tonnage First, Safety Last!
Golden-Arm is offline
post #14 of 17 Old 07-25-2020, 01:28 AM
Uniblurb
Uniblurb's Avatar
If you look at the info below from the Dorman site if you were to just buy the 2 upper outer bushings for the 99-04 WJ A-Arm it says they are directional and should be installed the same as OE.
https://www.dormanproducts.com/p-11578-905-203.aspx
https://static.dormanproducts.com/do...905-203_tn.pdf
If you have one installed one direction and the other installed in the opposite direction that doesn't sound correct. I'd try to exchange it.
Below is the whole A-arm link on the Dorman site.
https://www.dormanproducts.com/p-82367-522-476.aspx
Their front view photo below is so dark in the back it's hard to tell but it does look like both bushing wide metal parts should face up.
The bottom view definitely looks like both rubber parts of the bushing are pointed down. You'd think somebody could dust the arm off before taking a photo to make it sell. Guess not..
PS. these photos are posting too small on the forum and likely it's better to zoom them in the link above.
Uniblurb is offline
post #15 of 17 Old 07-25-2020, 05:27 PM
Bigrigr
Bigrigr's Avatar
Whoops! I have seen the discussion about the bushings being directional before, but have never seen anything definitive as to why....Now i see that i have probably installed them into my used control arm incorrectly. Ignorance is bliss...Thanks for ruining that for me Uniblurb...HAHA
'00LMTD-4.7l,242hd,D30,D44A,3.73's,True-trac front,Spartan rear,4" short arm lift,JK'sW/32's
Bigrigr is offline
