Can the same remote be programmed for multiple WJ Jeeps? - JeepForum.com
post #1 of 6 Old 10-10-2021, 09:07 PM Thread Starter
gdk771
Does anyone know if the same remote can be programmed to two different WJ Jeeps? I would think it would be possible as the ECU would not know if the remote was assigned to another unit, it just learns the code from that particular remote but perhaps there is more to it than that.
Has anyone ever been able to do this successfully? It would be nice to just have one remote with two WJ keys on it depending on which one I want to drive that day.
Thanks for any suggestions or comments.
gdk771 is offline
post #2 of 6 Old 10-10-2021, 10:00 PM
JonMopar
Short answer: no
Differing frequencies aside, Key fobs don't actually rely on different frequencies to identify themselves. They have digital authentication (let’s call it a “code”) programmed to a specific vehicle, even if those vehicles share the same frequency. Each button has its own corresponding code, so theyl car knows the difference between lock, unlock etc
98 Laredo ZJ 4L -3.73, 5.9 "ultrastar" rims, slotted brakes, Dynomax turbo, CAI.
JonMopar is offline
post #3 of 6 Old 10-10-2021, 10:10 PM
Brallen86
Brallen86's Avatar
2003 WJ
As JonMopar stated, no, he is correct.
I recently added 2 more fobs to mine via the dorman programmer and played around with it a bit while doing such. I can confirm that I had no luck in this theory, anything above 3 fobs also seems to be difficult without one fob suddenly not working after adding a 4th.
You could put 2 fobs back to back in a custom case but probably more confusing then anything at that point
-03 WJ Limited; Check out my
Brallen86 is offline
post #4 of 6 Old 10-10-2021, 11:51 PM Thread Starter
gdk771
Thanks for the info..
What I meant was if I have 2 key fobs programmed for one WJ, can I also program the same two fobs to work with a second WJ as well. In other words, if I press unlock on the fob it will unlock both vehicles.
gdk771 is offline
post #5 of 6 Old 10-11-2021, 04:03 AM
Waterluvr
Waterluvr's Avatar
You sure can, they can be added to as many compatible vehicles as you like the programming code is stored in the passenger side door module.
Waterluvr is offline
post #6 of 6 Old 10-11-2021, 09:04 AM Thread Starter
gdk771
OK Thanks waterluvr
That is what I was hoping was the case. I was planning to put both keys on the same fob and use it for both vehicles depending on which Jeep I am driving that day.
It sounds like you can only program a max of 4 fobs from what others have said but I only currently have two at this point. I might pick up a third one just to have a spare fob. They are all over eBay pretty cheap.
gdk771 is offline
