Can I force the PCM to recalibrate more quickly after an O2 sensor installation? - JeepForum.com
post #1 of 9 Old 01-17-2012, 02:02 PM Thread Starter
josephmartins
Long-time Jeep Nut
josephmartins's Avatar
Shortly after a CEL for one of my upstream O2 sensors I experienced a huge drop in fuel efficiency--about 50%. I am going to change the sensors tomorrow. Is there a way to speed up the time it seems to take the PCM to adapt to the new sensors? Or is driving and time the only solution?
Kind regards,
Joe Martins
Milford, NH
12 Wrangler Sahara JK8, 01 WJ Limited, 96 XJ Classic, 00 XJ Sport, 90 XJ Wagoneer, 97 ZJ Limited, 5.2, 98 ZJ Limited, 5.2
josephmartins is offline
post #2 of 9 Old 01-17-2012, 02:10 PM
Double E
Double E's Avatar
Disconnect battery, then touch disconnected battery cables together or depress the brake pedal several times while disconnected.
Clean battery contacts while your in there. Clean out your throttle body & IAC valve too for good measure.
Change fuel filter if you want to really stack the maintenance/mileage deck in your favor.
'04 Freedom Edition HO & '04 Overland HO (previous '00 Laredo 4.7)
Double E is offline
post #3 of 9 Old 01-17-2012, 07:27 PM
specia1k
Why would you touch the battery cables? I agree with disconnecting the battery, the reason being that you don;t want any electrical shorts, etc. to take place when replacing engine components (i.e. O2 Sensors, other sensors, spark plugs, etc.). I'd be interested to hear the logic behind touching the pos & neg terminals together. Would be weary of following that suggestion without details to support the comment.
2017 Jeep Grand Cherokee Laredo 2x4
specia1k is offline
post #4 of 9 Old 01-17-2012, 07:39 PM
MeanGreenZJ
Doing that is not a good idea on VIN coded PCM's. You can end up with a corrupted VIN in the PCM with a start stall issue. It's rare but it does happen even from something as simple as the battery going dead.
MeanGreenZJ is offline
post #5 of 9 Old 01-18-2012, 12:37 AM
ratmonkey
R.I.P.
ratmonkey's Avatar
Look up the driving cycle to quickly set the monitor cycles. It's actually almost impossible to follow without a closed course to drive.
ratmonkey is offline
post #6 of 9 Old 01-18-2012, 06:40 AM
Terminator2
http://www.youtube.com/watch?v=h87IC...2mDEAXdoIjPnhc
That is so rare it is not even funny. It is about as likely as you being struck by lightning. How many hundreds of millions of cars have dead battery issues worldwide each year? How many of those result in corrupted ECMs? Probably less than 1 out of every million.
Terminator2 is offline
post #7 of 9 Old 01-18-2012, 11:10 AM
BandGauto
You can disconnect the positive cable from the battery (leave the negative hooked up) and touch the positive cable to any good ground for 30 seconds or just hook up an OBDII scan tool after you replace the 02 sensor and erase the code. It will then take a few driving cycles for all the monitors to reset. If you have a decent scan tool it will tell you which monitors are reset and which are not. If you dont have a scan tool most auto parts stores like autozone will do it for you. Also after changing the 02 sensor make sure the 02 fuse in the distribution box (under the hood) didnt pop and replace it if it did.
BandGauto is offline
post #8 of 9 Old 01-18-2012, 01:24 PM
MeanGreenZJ
I'm not sure what the ratio of this issue is worldwide. But people still do play the lottery.
post #9 of 9 Old 01-18-2012, 01:27 PM
MeanGreenZJ
If you have a decent scan tool it will allow you to reset the PCM without disconnecting the positive cable from the battery.
Transmission Input Shaft Speed Sensor, Output Shaft Speed Sensor CaRJoE0220 WJ Grand Cherokee Forum 12 10-29-2014 05:47 PM
CPS (Crankshaft Postion Sensor) Removal and Installation jakj WJ Grand Cherokee Forum 1 07-05-2011 07:59 PM
Dynomat installation Knoxes WJ Grand Cherokee Forum 16 06-17-2011 02:56 PM
Jet V force plus??? stumy71 WJ Grand Cherokee Forum 0 03-19-2011 08:11 AM
Light Force Off Road Lights Bubba3200 WJ Grand Cherokee Forum 5 01-06-2011 05:02 PM
