Burning gas, bucking & serging - JeepForum.com
post #1 of 4 Old 05-15-2019, 03:47 PM Thread Starter
KellyannD
2000 Grand Cherokee Laredo
Started out with a backfire & black soot on the ground & tail pipe. From that moment, I burned through a tank of gas every 2 days. It wasn't doing anything else except for a very rare hiccup (buck) while driving.
Replaced the coil pack, spark plugs & pcv valve & hose. The valve only because it basically crumbled apart and had to be placed.
Since that ^^^^^ it is not burning through gas anymore but now it shakes & rattles, vibrates, idles poorly and has no get up & go power. Once I do get to 60-70 mph, if the cruise is on it has big power surges. Engines kicks in & rpms race up to 4+. Takes a good 20 sec for it to kick in to gear and level out again unless I turn the cruise off.
Am I looking at fuel injectors now or, before I spend that amount of money, could it possibly be something else??
KellyannD is offline
post #2 of 4 Old 05-15-2019, 06:48 PM
leadsled jeep
leadsled jeep's Avatar
With running conditions like those there should be some error codes I’d think. O2 codes maybe large vacuum leak.
'02 4.7HO ~222k ml. 2.5" BDS Springs, All new control arms and Addco Sways. 245-70-17.
leadsled jeep is offline
post #3 of 4 Old 05-15-2019, 08:54 PM
Mattyjm
Mattyjm's Avatar
I'd think PCM or Throttle Position Sensor along with Idle Air Control Valve.
2004 Special Edition WJ. LOADED!
2004 Rocky Mountain Edition. Froggy Bandit. Wife's Daily Driver. PRISTINE! Stock height and may stay that way.....
Mattyjm is offline
post #4 of 4 Old 05-16-2019, 01:14 PM
grayWJ4x4
1936 CJ2A
Clean or replace the idle air sensor and check for codes for the crank position sensor.
grayWJ4x4 is offline
2002 Jeep Liberty 3.7L engine only starts with gas and shuts off if i let go of gas. Ap23242324 KJ Liberty Forum 11 11-28-2019 09:20 PM
My goal is to get 25+ mpg from my 99 XJ with 30 x 9.5 R15 ATs Charley3 XJ Cherokee Technical Forum 3864 10-19-2019 10:58 PM
TJ running rough gas stinks bad, bogging down at times and back firing mgaither0 TJ Wrangler Technical Forum 15 06-23-2019 11:45 AM
gas tank leak Kristian_Burns TJ Wrangler Technical Forum 5 06-14-2018 06:01 AM
Pure Gas in Denver Area txdutt JK Wrangler Technical Forum 2 04-20-2018 09:00 AM
