JeepForum.com (https://www.jeepforum.com/forum/)
-   WJ Grand Cherokee Forum (https://www.jeepforum.com/forum/f310/)
-   -   Burning gas, bucking & serging (https://www.jeepforum.com/forum/f310/burning-gas-bucking-serging-4355977/)
KellyannD 05-15-2019 03:47 PM
2000 Grand Cherokee Laredo
Started out with a backfire & black soot on the ground & tail pipe. From that moment, I burned through a tank of gas every 2 days. It wasn't doing anything else except for a very rare hiccup (buck) while driving.
Replaced the coil pack, spark plugs & pcv valve & hose. The valve only because it basically crumbled apart and had to be placed.
Since that ^^^^^ it is not burning through gas anymore but now it shakes & rattles, vibrates, idles poorly and has no get up & go power. Once I do get to 60-70 mph, if the cruise is on it has big power surges. Engines kicks in & rpms race up to 4+. Takes a good 20 sec for it to kick in to gear and level out again unless I turn the cruise off.
Am I looking at fuel injectors now or, before I spend that amount of money, could it possibly be something else??
leadsled jeep 05-15-2019 06:48 PM
127 Attachment(s)
With running conditions like those there should be some error codes I’d think. O2 codes maybe large vacuum leak.
Mattyjm 05-15-2019 08:54 PM
I'd think PCM or Throttle Position Sensor along with Idle Air Control Valve.
grayWJ4x4 05-16-2019 01:14 PM
Clean or replace the idle air sensor and check for codes for the crank position sensor.
The time now is 04:18 AM.
Copyright ©2000 - 2020, Jelsoft Enterprises Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
