Are bump stops really needed? - JeepForum.com
post #1 of 9 Old 02-24-2020, 09:05 PM Thread Starter
Blasterkid305
Blasterkid305's Avatar
I have a 2000 JGC 4.0 with a 2 inch lift and on some stock JK rims and tires I went under it yesterday to change out the track bar bushings and noticed I no longer have any bump stops in the front should I replace them or are they really not needed because I lifted it 2 inches? Thanks in advance
Blasterkid305 is offline
post #2 of 9 Old 02-24-2020, 09:30 PM
4WDlifeform
4WDlifeform's Avatar
Depends on your use. Daily driving, you'll probably never cause any damage. But, if you wheel it, the next thing that stops your travel is probably your shocks. So, you'll blow through those. And, with JK tires you'll likely rub and catch your fenders, causing other damage.
'04 WJ 4.0, 325k miles! 2" Coils 255/70 AT on JK take-offs
-sold- '14 KL Trailhawk
-sold- '97 XJ AX-15, 3" lift
Any tool dropped while working on your Jeep will roll underneath to the exact center.
4WDlifeform is offline
post #3 of 9 Old 02-24-2020, 10:19 PM
Klarah523
Klarah523's Avatar
Pushing a stock up through a unibody is never a good thing. Or bending a shock. Or both.
Klarah523 is offline
post #4 of 9 Old 02-24-2020, 10:23 PM
Klarah523
Klarah523's Avatar
*pushing a shock (still a n00b, can't go back and correct typos)
post #5 of 9 Old 02-25-2020, 10:47 AM
GmanWJ
GmanWJ's Avatar
When the suspension bottoms out, you will appreciate having bump stops in there. They are inexpensive and not difficult to install, you just shove them in there. Get some.
ok mostly just repairs, but we are closing in on a lift
GmanWJ is offline
post #6 of 9 Old 02-25-2020, 11:25 AM
smokeyyank
What 4wdlife said is spot on.
04 WJ, 4.7HO
3" IRO lift, fastman TB, 32s, lunchbox rear 242HD, 3" exhaust
smokeyyank is offline
post #7 of 9 Old 02-25-2020, 09:21 PM
ParkerStovall42
Pull some from a junkyard and shove them in there. You don't need them until you do. I'd way rather a pothole wipe out a $3 bump stop than anything else.
ParkerStovall42 is offline
post #8 of 9 Old 02-26-2020, 09:05 AM
Bigrigr
Bigrigr's Avatar
Look for the extended bumpstops since you have a small lift. Many places carry them on line. If you have bigger tires and a lift, you need bigger bumpstops to keep from smashing your fenders and cutting up your tires.
'00LMTD-4.7l,242hd,D30,D44A,3.73's,True-trac front,Spartan rear,4" short arm lift,JK'sW/32's
Bigrigr is offline
post #9 of 9 Old 02-26-2020, 10:54 AM
Double E
Double E's Avatar
Cheap as heck from RockAuto. The OEM disintegrate over time hence why they fell out. Just crap material from Jeep. The new ones seem to be made of different material.
If your suspension ever bottoms out, you'll realize what they are there for.
'04 Freedom Edition HO & '04 Overland HO (previous '00 Laredo 4.7)
Double E is offline
